ordered springs and sway bars
Old May 28, 2007 | 01:43 PM
tomservo's Avatar
Default ordered springs and sway bars
So I finally turned over cash and bought my first two mods. I got the H&R springs and IPD sway bars. Looking forward to the install and use. I know this my be small to some, but I am excited (and poorer). Wish me luck!
Old May 28, 2007 | 02:14 PM
Default RE: ordered springs and sway bars
IPD sway bars are the best suspension upgrade you can do to your car other then KW Coilovers.
I had IPD sways on my 1995 850 NA and loved them so much. Also had lowering springs and a strut brace on the car as well. The car handled wonderfully.
I plan to get IPD sways for my s70 that I have now.
Also H&R springs are good.
You will be very happy with this setup.
I would also recommend IPD HD sway bar endlinks and or the QBM sway bar endlinks that QBM, Viva Performance and IPD sell.
Old May 28, 2007 | 07:46 PM
tomservo's Avatar
Thanks for the suggestion. I will def. look into the end links. I think next on the list will be decent tires. The Goodyear M+S are decent, but don't really handle. Plus I think it's a 60 or 65 series. I figure I will try to find a 50 that will fit in a summer only tire. I have a set of blizzaks for the winter.
Old Jun 11, 2007 | 06:22 AM
tomservo's Avatar
I suck. I got the front springs changed. Working on the back and I snaped the pass. side lower shock bolt off. Not good. I have it towed to the local Volvo shop. Hopefully they can just cut the old bolt out and put in a new one. But I was about 2 1/2 hours from home. So now it's there and I'm here. I'm and idiot.
Old Aug 25, 2007 | 08:32 PM
my_volvo's Avatar
so im thinking about getting EVOLVE Sport Lowering Springs for my 2006 electric blue volvo s40. would you guys recommend evolve's lowering springs or would you get some else where?
Old Aug 25, 2007 | 10:38 PM
ORIGINAL: my_volvo
Personally I would get another brand. I suggest you search to see what is available.
Old Sep 6, 2007 | 06:32 AM
wallie's Avatar
If you upgrade to IPD sway bars you really should get an upgraded end link or else you'll be bending them, I know of a few that have. I have the QBM 3rd gen in my 97 854R along with the IPD sways, OMP springs and Koni yellows, I like how it handles. If you get the QBMs make sure you get the rubber boots that cover the joints, other makes have boots too some don't but they're key to lasting longer.
Old Sep 16, 2007 | 09:57 AM
tomservo's Avatar
I had to send the sway bars back. My "I can do it attitude" cost way more than having someone else do it would have. But it sounds like that might have been a good thing. When I do have the ability to order the sway bars, I'll make sure I get supporting pieces as well. Thanks all.
studioz
Feb 9, 2012 02:03 AM
Hi555
Nov 10, 2010 10:13 PM
tommy_a
Suspension
Jan 16, 2007 05:50 PM
Samhem
Suspension
Dec 20, 2006 01:17 PM
lumanikus
Jul 26, 2005 08:36 PM
