any input on a 1998 v90,I am close to buying one sat. one
Old Mar 22, 2005 | 10:25 PM
john's Avatar
Default any input on a 1998 v90,I am close to buying one sat. one
Hi , I had a 1993 240 standard but I was always shifting due to lack of power . I am looking for a safe ride , a little more zip , and rear wheel drive. the dealers around here have all been pointing me to 1996 and up 960,s and v90,s. I found a clean 1998 v90 with 94000 miles. I am suppose to pick up Sat. I have seen and heard good and bad about this car . Also my 93 seem to have a lot of " well they all do that" . Has volvo gotten better !!! . should I buy or should I walk away? I am driveing a 1996 ford t-bird and my toy is a 1966 cobra replica. She took me 3 years to build. thanks for any input on this one.
Old Mar 22, 2005 | 10:28 PM
Default RE: any input on a 1998 v90,I am close to buying one sat. one
The V90's are good cars.Make sure you drive it good first.As long as everything feels good go for it.
Old Mar 23, 2005 | 07:51 PM
john's Avatar
Hi thank you for your input , There where some very steep hills where I test drove the v90 and the car feels real solid . How hard is this car to work on ? Or will I have to send her out for every thing . I like to do oil changes ,brakes, and other mantainance on my own. I never did a timing belt is it much harder then a timing chain ? do you need any special tools to do this ? thank you for any input. have a great day...
Old Mar 23, 2005 | 09:06 PM
The maintance is very easy.The car overall is easy to work on.If you have done a timing chain before then this will be cake.The timing belt isn't hard to do.You won't need any special tools as long as you have a Vise on a work bench.
Old Apr 24, 2005 | 12:20 PM
bmorrill's Avatar
John,
This may be too late (Sunday), but I have a '98 V90 and the front brakes have always been a pain. Regardless of how many times we've taken it to the dealer, the brakes always grind at the end of braking cycles, continually "glaze" over, and require constant servicing (btw, $800 to replace again and again...). I'm getting tired of it, and wonder if anyone else has had these problems with this model and/or solutions for it. The service guy keeps saying we're "riding the brakes" and that is simply not the case. We use to own an '87 740GL wagon (and other cars as well) and never had those brake issues. Having said that, I've been happy with everything else about it; it is a comfortable ride and good, peppy road handler.
Tech,
Any input on the above-mentioned brake issue? Can I "upgrade" the brakes to take care of it?
Thanks!
Brian
Old Apr 24, 2005 | 04:26 PM
ORIGINAL: bmorrill
John,
Tech,
Thanks!
Brian
What break issue?
Old Apr 27, 2006 | 04:19 AM
Mojav's Avatar
I have a 148k, Volvo 940 SE wagon which has brake problems too. Seems to go thru brakes rather quickly. I would like to beef up the rear end and susp. but can't afford it just yet. Enjoy the car, its got good power.
Mojav
Old Jul 10, 2006 | 07:19 PM
john's Avatar
hi ! I printed out a long question about buying a 1983 242 turbo and it is under Alans pictures of his mustangif you could please backtrack and then give me your input that would me my day as I am a really slow typer. thanks for the help.
timtatum
Jan 8, 2025 09:44 AM
martin calva
Apr 15, 2015 04:59 PM
jean1222
1998-2000 model year V70
Jul 13, 2013 07:49 PM
sia23
Dec 3, 2012 07:15 AM
TONTO
Sep 20, 2005 10:37 AM
