resetting the service light
Old Oct 27, 2003 | 07:23 PM
bongo240's Avatar
Default resetting the service light
I looked and look ...but cannot find the button/cover on the dashboard near the speedomiter....</P>
can anyone help me find where I have to go to reset the service light </P>
please please please</P>
thank you</P>
bob</P>
Old Oct 28, 2003 | 03:27 AM
Erock198's Avatar
it should be there. It might be covered by a rubber grommet
Old Oct 28, 2003 | 02:49 PM
roning's Avatar
Yah. There should be a rubber grommet on the instrument cluster plastic cover. You should be able to push it with a small star screwdriver or similar sized pin while sitting normally in the driver's seat. If not, you've got the under the dash switch which I've heard about depending on your model. Good luck.
Old Apr 1, 2004 | 05:56 PM
pilotsims's Avatar
i know that on my model (91 240), the light goes out after so many miles. I was told when i got the car that the light was simply for reference that it would be wise to check ur car but that it did not mean nething was wrong. if you cant find the reset, just let it go out by itself
Old Apr 1, 2004 | 06:33 PM
Erock198's Avatar
On the 240, I think it is directly behind the kick panel and accessible by removing the cover above your knees. On the 7XX series it is on the speedo under the grommet. It comes on every 7500 miles to tell you to change your oil and check your car over. The light will not go out unless you reset it.</P>
</P>
</P>
boxpin
Oct 10, 2009 06:41 AM
ken8052
Apr 14, 2009 09:41 PM
rich nc
Mar 22, 2009 04:15 PM
whome
Oct 24, 2008 05:17 PM
master_pre
Aug 21, 2006 09:01 AM
