Transmission whining ? Should I worry?
Old Mar 26, 2005 | 07:25 PM
johnhon's Avatar
Default Transmission whining ? Should I worry?
I recently bought a used 1998 V70 XC AWD Turbo automatic with 110,000 mi. It is a very nice car and everything has been fine with it except for a whining noise that seems to be coming from maybe the transmission? It is an occasional noise that starts when the car is in drive, at about 30 mph and gets louder when decellerating and stops when the car stops. The whining will dissapear after about 2000 rpm. but below that it comes and goes. The noise is a hi pitched noise like a very quiet turbo engine. The only thing that makes sense to me is that is the transmission. Trans. fluid is good. Should I be worried about this? Is there anything I can do to troubleshoot further?
Is this year/model prone to transmission problems?
Thanks for any advice.
Old Apr 29, 2005 | 11:49 PM
robaincltnc's Avatar
Default RE: Transmission whining ? Should I worry?
Lookout..mine started whining at 70k and it was the angle gear (part of the AWD system). The part was $1800 if that tells you anything. Is the noise getting worse?
Old May 22, 2005 | 09:55 AM
johnhon's Avatar
Thanks for your input. No, the noise is not getting worse, but it has disappeared recently. How did you determine the problem in your car? Did the noise get progressively louder?
mattlach
Jul 4, 2013 10:32 PM
Kev75
Jun 30, 2011 09:56 PM
lalawhipper
Jan 5, 2009 09:56 AM
not4long
Nov 8, 2007 07:17 PM
phjohnso
Mar 23, 2007 08:36 PM
