A/C Blower Motor bad?
Old Jul 1, 2007 | 03:09 AM
wagonman's Avatar
Default A/C Blower Motor bad?
I have a 98 V70 GLT that has an issue with the A/C blower motor I believe. The A/C blows ice cold but after driving awhile (maybe 30miles) the blower motor (I think) starts to get very noisy and the level of air coming from the vents is decreased. When I try to manually increase the blower speed on the control the level of noise from the motor increases as well, but still have little air coming out. Could the motor and or resistor pack be bad? Is it overheating possibly after being on for awhile. Anyone else experience this? Thanks in advance for any help.
Wagonman
Old Jul 1, 2007 | 07:52 AM
Default RE: A/C Blower Motor bad?
Sounds like the Low pressure switch is bad and the Evaperator is freezing up.
When that happens again quick open the hood and see if the pipes going into the car are frozen.
Old Jul 1, 2007 | 04:58 PM
wagonman's Avatar
Thanks Tech. I 'll give it a look next time it happens and let you know what I see. Appreciate the help!
Old Jul 13, 2007 | 02:39 PM
bashley's Avatar
Hi -
Any idea where that low pressure switch is? This sounds like the same probalem I have on my 2000 V70 XC.
brian
Old Jul 14, 2007 | 07:38 PM
99VolvoV70's Avatar
I don't know if the 2000 is the same as the '99, but this is where the pressure switch is located on my 99 V70. It's probably in a similar location, I'd expect. By the way, I replaced mine when I was working on the A/C, but I don't think it really needed replacing. I ordered it from www.eEuroparts.com for about $80. Check there for your car, if the part number is: A/C Pressure Switch (8628563), let me know and I'll send you my old one which is probably still working. Here's the location of the switch.
[IMG]local://upfiles/10409/42D8529E469F4C44BD467BF4AC8B2252.jpg[/IMG]
Old Jul 14, 2007 | 07:39 PM
99VolvoV70's Avatar
Btw, in that picture, the switch was already disconnected, but that's where it plugs in.
Old Jul 14, 2007 | 08:07 PM
The low pressure switch is in the pipe at the firewall.
The one in the pic is the high pressure switch.
Old Jul 14, 2007 | 11:33 PM
99VolvoV70's Avatar
Thanks, tech! That's why it's great to have you back from vacation. I could have figured that out if I'd traced through the diagram (you don't have high pressure through the evaporator!). Oh well, thanks for the correction - here's my corrected pic for completeness.
[IMG]local://upfiles/10409/33517BE9D30D4974AABD98195F1F410A.jpg[/IMG]
Old Jun 20, 2010 | 09:09 AM
Ingimar's Avatar
Can you please post that picture again since the link is not working anymore
Old Jun 21, 2010 | 02:13 PM
kpmg08's Avatar
Default low pressure switch
It appears I have a similar problem with my '98 V70. How is the low pressure switch changed?
Is this a DIY endeavor or only for someone with access to freon etc?
97black850
Feb 14, 2015 05:31 PM
elcs70
Aug 2, 2012 03:03 PM
jmallie
Sep 17, 2009 09:47 AM
stein1535
Jun 27, 2009 07:18 PM
ENDEE666
Dec 2, 2006 06:33 PM
