240 front seats inside foam has moved
Old Oct 31, 2003 | 01:18 PM
bongo240's Avatar
Default 240 front seats inside foam has moved
</P>
I have 2 - 240,s now a 89 and a 90 and on both of them the inside of the front seat , the foam has shifted and you can feel the steel on the inside portion of the back part of the seats.... has anyone had this happen and is there anything I can do to reposition the foam so that it is over the steel..???</P>
</P>
please reply </P>
thank you</P>
Old Jun 10, 2004 | 12:31 AM
Larry's Avatar
Bongo, had similar problem on my 81 240 GL. Took the seat cover off and found that I had to replace some wires, springs, and reglue some of the foam. The price of the replacement foam was way out beyond Pluto, if you know what I mean. You will have to open up the hog rings to get the seat cover off. It a bit of a chore to get everything right when you put it back together. Cheers.
Karen
Feb 14, 2022 07:47 PM
arni76
Nov 15, 2014 10:36 AM
TheVolvoMan
Apr 26, 2004 10:07 PM
chipg2
Apr 18, 2004 09:46 PM
TheVolvoMan
Apr 18, 2004 08:44 PM
