squeaking glovebox-driving me NUCKING FUTS!!!!!!
Old Apr 11, 2005 | 01:24 AM
Steamroll9's Avatar
Default squeaking glovebox-driving me NUCKING FUTS!!!!!!
Alright, i got my 2002 C70 Coupe mid-December and i live in NY. obviously it's been on the chilly side here. Now that it's warming up, a squeak is coming from my glovebox. At night, when the temp drops, the noise disappears. It happens when I go over bumps, even little ones. if i tap the glovebox when still, it makes the sound. seems to happen when the sun has been shining on the car for awhile and it's over 50 degrees or so.
I have tightened all the screws, no help. It is really starting to get on my nerves.
Anyone else ever have this problem? any fix's? it is still under warranty, but as we know, some problems are better taken care of on your own, if possible.
thanx in advance!
Old Apr 11, 2005 | 01:25 AM
alecw81's Avatar
Default RE: squeaking glovebox-driving me NUCKING FUTS!!!!!!
Maybe a piece of dynamat would help?
Old Apr 11, 2005 | 01:51 AM
Sit in the passenger seat and grab the dash and pull on it and push on it and see if it makes the noise.The mounting tabs are breaking on the dash sometimes.Then if it is take it in and complain and make them fix it.You can also put a little peice of foam inbetween the glove box door and the dash and see if it helps.
Old Apr 26, 2005 | 11:21 AM
JimKW's Avatar
On the radio there is a **** on the left hand side. Turn this **** clockwise until the squeaking disappears.
That's probably why I need go have my hearing tested.
Old Apr 27, 2005 | 11:35 PM
reg's Avatar
reg
Re: the c-70 still under warranty....................do not hold your breath that Volvo is going to repair it "for free". Squeaks and rattles are not considered. Unless, and as Tech mentioned, the tabs are actually broken, you are out of luck for warranty repair.
Old May 10, 2005 | 04:32 PM
Steamroll9's Avatar
just to update you guys. I took the car in for service, and they told me that they lubricated something, not sure what. The noise is still there but not as much and is a bit more muted. guess it needs to be lubed a little more. Thanks for the help!
Old Feb 16, 2006 | 11:55 AM
c70turbogt's Avatar
the lube will wear out... had the same problem... what u need to do is get something to stick between the door and the and the base so you isolate the hinges... that will make it impossible for the metal on metal to rub
cheers
Wrowley11
Jul 26, 2012 09:52 PM
kevo409
Apr 23, 2008 07:51 PM
uncle
Feb 22, 2007 12:38 AM
cool_kyle_3000
May 30, 2006 10:56 PM
Nand12
Aug 20, 2005 11:53 PM
