Brake Light failure
Old Apr 11, 2005 | 05:38 PM
rbnatx's Avatar
Default Brake Light failure
Has anyone experience a problem with the brake lights failing repeatedly. I went to change the bulb, and noticed immediately that the old bulb was way hotter than it should be. I replaced the bulb and while I was testing out the new bulb it burned out as well. I have scheduled a service appt. for my 01 2.4t. But would like to know what might be causing this.
Old Apr 11, 2005 | 06:03 PM
Default RE: Brake Light failure
I haven't seen that before.I could see maybe a month or so with the track record with these cars.But that fast is not to good.
Old Apr 15, 2005 | 12:16 PM
rbnatx's Avatar
Well it is back from the dealer after the 22,500 mile service. The dealer tells me that you have to replace all bulbs in that circuit at once. So they just replaced every bulb to be found in the back of the car and they work just fine.
Old Apr 15, 2005 | 01:03 PM
Your are better off that way or you will replace 1 and then another a day or so later then again and again.
Old Dec 20, 2005 | 08:29 PM
gotawd11's Avatar
Hey tech,
So we got the brake light failure message and took it to the dealership and they replaced the bulbs but they said for them to work some computer module needs to be reset or replaced and want to charge us $700. Does this sound normal? or are they trying to scam? thanks Justin
Old Dec 20, 2005 | 09:24 PM
Does the lights work at all?
Is only one bulb out?
Old Dec 24, 2005 | 05:32 AM
gotawd11's Avatar
Yes some of the brake lights work, the dealer replaced two of them, but they couldnt get them to work. they said they tried to load an update in the REM, but couldnt. then stated the Rear eletronic module was bad. however back up, center brake light and some of the other brake lights work, just two big bulbs dont. thanks Justin
Old Dec 24, 2005 | 10:24 AM
Usually when the Rem goes bad you will loose alot more things. The rear door locks won't work,And other things in the back of the car.
If the big bulbs won't work then I assume only the 3RD brake light is the one working.
Old Dec 25, 2005 | 03:56 AM
gotawd11's Avatar
Ok, so we replaced the bulbs how do we get them to work? what else needs to be done, because even after replacing them they only worked a few minutes. Im really new to volvo so a detailed description would be very appreciated. thanks justin
Old Dec 26, 2005 | 02:17 AM
Bender's Avatar
hummm. I would say step number one is getting it to someone else for a second opinion.
Your REM could be bad, but it is most likely not. What year is your car? How many miles? What sort of waranty?
Old Dec 26, 2005 | 11:48 AM
It might be a bad Rem but hard to tell without seeing it and puling codes from it.
It still seems funny that you put in new bulbs then it works for a few then stops working.
Old Dec 26, 2005 | 08:03 PM
gotawd11's Avatar
Its a 01 s60 with about 80000 miles, no warranty left. I will get you the codes soon. thanks Justin
Old Dec 31, 2005 | 05:47 PM
gotawd11's Avatar
So we had the codes ran and no codes came up. However under futher examination we found that not only do the outside brake lights not work, the parking lights stay on all the time. whether parked or not?? anyway, Im guessing there is a bigger problem here. Is there a sensor with the brake pedal/E-brake that could be keeping the parking lights on? but that still doesnt explain the brake light not working. so any information would be helpful. thanks Justin
Old Jan 2, 2006 | 12:11 AM
If no codes show up check from the brake light switch and make sure you get power from the switch.
Old Jan 2, 2006 | 11:25 PM
gotawd11's Avatar
ok Tech, where is the switch and what does it look like? thanks Justin
Old Jan 3, 2006 | 12:26 AM
Look about half way up the brake pedal arm. There should be a switch about half way up. You can check there for power. Also see if it is touching the pedal arm.
cheebster
May 8, 2014 04:31 PM
jasonthaynes
Dec 2, 2012 05:32 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
soulfulimpressions
Jul 31, 2008 07:07 PM
