Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 08-15-2007, 04:05 PM
animal40 animal40 is offline
Default 1994 volvo 850 won't start
Started my 850 estate yesterday lunch time it ran for about 3 seconds then cut out and has not started since.
Called out the AA the engine has no spark, no injector pulse and a camshaft sensor fault code.
The AA mechanic said the crankshaft sensor was not putting out enough voltage aaprox 0.26V.
Have replaced crankshaft sensor and camshaft sensor today.
Engine turnes over but still wont start, dose not even try.[&:]
[:@]PLEASE HELP!
Old 08-15-2007, 04:30 PM
RedTurbo850 RedTurbo850 is offline
Default RE: 1994 volvo 850 won't start
But the ignition in slot II and have a friend listen near the pass. side rear wheel and see if they hear the fuel pump priming. Also, crank the engine and have a friend bang on the fuel tank a couple times.
If your car starts w/ the banging technique, your fuel pump is toast. IF you dont' hear it priming, either your pump is toast or your relay is toast.
Did the mechanic do anything about the spark?
__________________
Old 08-15-2007, 04:43 PM
The AA mechanic said the crankshaft sensor was not sending a strong enough signal to the ECU hence no spark, no injector pulse but i have replaced both of these.
I have recently replaced the fuel pump relay and have good presure at the fuel rail.
Totaly Baffled????
Old 08-15-2007, 04:51 PM
If you have good pressure at the fuel rail...
Then your issue is spark.
Remember, three things to start a car. Fuel, Air, Spark. You need to test and see if you have spark.
__________________
Old 08-17-2007, 02:26 PM
Justchecked for a spark andasthe AA mechanic said there is no spark.
Old 08-17-2007, 02:57 PM
JimKW's Avatar
JimKW JimKW is offline
Could be coil or Cam Positon Sensor.
__________________
Old 08-17-2007, 05:43 PM
tech tech is online now
I would look at the Cam Position sensor before the coil.
__________________
1995 Yellow T5-RM yes Manual
1996 850 turbo
Old 08-17-2007, 06:34 PM
JPN's Avatar
JPN JPN is offline
Hello mate,
Greetings from Narita, Japan.
I just went through the factory manual and it says the CMP sensor output voltage varies between 0.1V to 5V during cranking.
I will attach the page that has CMP sensor testing procedure (a digital multimeter is required), as well as the location for OBD-I code-retrieving unit location in the engine compartment (not sure if '95 UK models come with OBD-II; OBD-II was installed on '94 and later US models). The socket for ignition module is A-6.
Please note that I'll be deleting themanual in the next few days so please save it in your PC, or you can get the same manual at: http://www.volvoclub.org.uk/volvo_wo...techdocs.shtml
I hope this helps. If not, come back again.
Cheers,
JPN
__________________
1994 854 Turbo T5, AW50-42LE
B5234T OBD-II Compatible
FAA-Airframe & Powerplant Ratings
FCC-General Radiotelephone Operator
Technical Translator (English-Japanese)
Certified Flammable Liquid Specialist
American at Heart
Old 08-18-2007, 08:30 AM
Fault codes found after ignition failure 3-2-4 / 2-1-4 / 1-3-1. I have replaced both sensors but still no spark. The AA mechanic said the coil was powering up ok but not firing. He also said that the injectors wer not receiving any signal.
Old 08-18-2007, 10:03 AM
All those codes refer to either the Cam or crank sensor.
131= RPM sensor signal absent.
214= RPM sensor signal absent Intermittently.
324= Cam position sensor signal absent Intermittently.
__________________
1996 850 turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
