Makin a 740 nonturbo to turbo advise needed
Old Sep 10, 2007 | 06:30 PM
gabyman97596's Avatar
Default Makin a 740 nonturbo to turbo advise needed
I want to put a turbo system in my 1990 740GLE they are selling everything I need the turbo intercooler and all the hoses I need for the car for $210, the problem is my car is not a turbo model can this be done will it damage my engine any advise please before I buy this
____________________________________
Gabyman97
1990 740GLE
1992 240DL
1994 940 Turbo Wagon
1999 S80 2.9
Old Sep 10, 2007 | 07:03 PM
Default RE: Makin a 740 nonturbo to turbo advise needed
1. Yes it can be done.
2. Yes it could potentially damage your engine if you do it wrong.
3. These are items you will need...
a. Turbo
b. Intercooler
c. Intercooler hard pipes
d. Turbo hoses
e. Vaccum lines
f. Downpipe
g. Oil or water lines
h. Etc....
Not to mention your going to need a way to control the boost. This is were TUNING comes into play and it is one of the most important things you need to do. A bad tune can ruin the whole thing. So do some research. If not become a member of TurboBricks they can help you out as well.
Old Sep 10, 2007 | 07:14 PM
Thanks for the fast reply my fellow s70driver well I'm takins the parts out of a 1988 740 turbo I don't know if it is the same system wich it uses the 1990 model anyways the vacuum lines and the oil or water lines where i'm going tofind this on the car . What do you think would it be trouble doing this upgrade to my car
Old Sep 10, 2007 | 11:19 PM
Shouldn't be too hard. It would be easier to sell and buy a turbo model. But this is a good start.
Old Sep 11, 2007 | 08:49 AM
TheSteelKnight's Avatar
I would like to stress, as long as it is done right!!!!!!!! If it is not, your engine is gonna start cussing you out every time you drive.
Old Sep 15, 2007 | 06:43 AM
There is a resistor pack that mounts inside the drivers side fender. It is for the injectors make sure you install it on your car or you will have running problems with the car.
79lilred
Engine & Internal
Oct 14, 2010 08:57 AM
rogue606
Jun 24, 2010 09:15 PM
SCVolvo
Dec 15, 2009 12:09 PM
Systek
Nov 17, 2007 12:47 PM
GaryBrad
Apr 24, 2007 11:48 PM
