Bright Lights
Old Apr 21, 2005 | 02:01 AM
Rich Solano's Avatar
Default Bright Lights
Okay, here is another question that I forgot to ask.
The bright lights on my '93 960 simply do NOT work.
If I pull for bright lights when the headlights are off, it doesn't flash. When the headlights are on and I pull it just turns off the headlights and fog lights and leaves the corner lamps on.
Do I need new bulbs, and if so, are the brights a seperate bulb from the standard headlights?
THANKS!
Old Apr 21, 2005 | 09:54 AM
Default RE: Bright Lights
Look in the fuse box under the hood for the headlight relay.
There is seperate bulbs for the highbeams.You can also check for power at the bulbs.
Newport_j
Dec 26, 2011 03:54 PM
vwzoo
Dec 25, 2010 02:35 AM
Dietzl
Apr 23, 2010 04:08 PM
imacuser12
Oct 22, 2006 10:10 PM
baldy7
Dec 21, 2005 02:30 PM
