Turbo's as opposed to fuel economy and engine wear.
Old Apr 22, 2005 | 01:36 PM
SwedishGermanCars's Avatar
Default Turbo's as opposed to fuel economy and engine wear.
I am assuming that a Turbo will increase wear on an engine and consume more fuel. Is that assumption correct?
Old Apr 22, 2005 | 02:51 PM
Default RE: Turbo's as opposed to fuel economy and engine wear.
The turbo uses a little more gas.The engines will last about the same time.
Old Apr 28, 2005 | 02:21 PM
alecw81's Avatar
That's only half true... there are plenty of cases where a turbocharged variant of an engine get's better gas milage than it's NA twin. Most Turbo-diesel trucks get better gas milage than non-turbo versions. Even old Turbo-diesel volvos average a better fuel economy than the NA diesels. My friends HIGHLY modified (t3/t4 50trim, biggie fuel system, huge FMIC) gets 47mpg in mixed driving conditions.
Old Apr 28, 2005 | 09:09 PM
reg's Avatar
reg
I agree with alecw81. I drive a C-70 with the high pressure turbo. I run Continental Conti Contacts 215 55 16 @ 32psi.. In addition I use Bosch platinum plugs gapped a tad wider than stock. Castrol synthetic oil in the crank case. At an indicated 75 MPH I recently obtained better than 30 MPG. That's not bad for a heavy auto!
Old Apr 28, 2005 | 11:32 PM
alecw81's Avatar
Platinum Plugs are less than ideal for turbocharged vehicles. Good old NGK Coppers will yield better performance (and cost a LOT less) If you must have bling bling plugs then go with the iridiums.
Old Apr 29, 2005 | 06:18 PM
Patrick's Avatar
i run platinums on everything...except for my drag car, which i change the plugs once a week or so...
Old Apr 29, 2005 | 11:49 PM
reg's Avatar
reg
For better than 20 years I have used Bosch platinum plugs. I have them currently in German, Swedish, Japanese, and British autos. After running SCCA events with a Hartge BMW and using literally every plug known to mankind I can speak with authority regarding Bosch platinum plugs. The mistake many make with them is gapping them to factory specs.................
Old Apr 30, 2005 | 05:22 PM
Patrick's Avatar
hmm...how do you gap them?
Old Apr 30, 2005 | 11:09 PM
reg's Avatar
reg
.15 wider than spec. I use the single electrode plug............not the Bosch double or quad plug. If running a high speed event you can go to .20 wider........you need a good spark.
nemotode
May 25, 2013 10:59 AM
bowlerhat
Apr 4, 2010 09:37 PM
clinic express
Dec 4, 2008 03:31 PM
ebrobb
Jun 12, 2008 12:42 PM
Vee70
Jun 10, 2008 06:50 PM
