GAUGES
Old Apr 26, 2005 | 09:41 PM
KNIN's Avatar
Default GAUGES
Today my gas and temperature gauge went to the max. I replaced the fuse, but still showing as the max. I checked the connection at the fuse panel and everything seems fine. How much work is involved in seeing the connections behind the instrument panel. Does the whole dash have to come apart? Do I have to remove the centre panel? Maybe I am missing something. Thanks for the advice.
Old Apr 27, 2005 | 01:46 AM
Default RE: GAUGES
Exactly which model do you have?
Old Apr 27, 2005 | 05:34 PM
KNIN's Avatar
Default RE: GAUGES
1978 262C
Old Apr 27, 2005 | 07:23 PM
Default RE: GAUGES
Im not 100% sure about the 262.I know on the 240 you remove the ***** from the headlight switches and dimmer switch and the panel will come off.Then you can remove the 2 screw on the one side.The other 2 are under the cover on the other side.
Bummer
Sep 6, 2011 09:58 PM
bli745
Oct 31, 2006 04:02 PM
flamejet
May 9, 2006 09:34 PM
woodpecker
Aug 12, 2005 07:05 PM
woodpecker
Aug 11, 2005 05:30 AM
