Reduced enging performance light ??
Old May 4, 2005 | 11:27 PM
Rick's Avatar
Default Reduced enging performance light ??
My 2.9l s80 will not start today, and I am getting this "reduced engine performance" on the dash display.
2003 that just had it's 60k services done...
Any ideas ??
Old May 5, 2005 | 01:08 AM
Default RE: Reduced enging performance light ??
You need to have the codes pulled.
Could be a bad mass flow sensor.
Could be a bad throttle body.
Could be many things thats why you need to have the codes pulled first.
Old May 5, 2005 | 07:15 AM
Rick's Avatar
I'ts going to the shop this morning...I'll post the results so others can know what's up...
Thanks.
Old May 5, 2005 | 09:42 AM
Thanks for updating the post.
That way it will help in the future.
Old May 9, 2005 | 05:01 PM
Phil's Avatar
I as well am receiving a "performance reduced" msg. Looks like there are problems with the throttle body.
http://www.autosafety.org/article.php?scid=119&did=817
Old May 10, 2005 | 09:30 PM
Rick's Avatar
Went to pick it up today.( they replaced the fuel pump) but only got 1/2 block before it died again....check engine light stayed on and would not start again....Waiting to hear from the Service Advisor ??? sigh...I love my car...dammit.
Old May 10, 2005 | 09:36 PM
It might be something as simple as the tech didn't have the pump unit set properly.
Old May 11, 2005 | 08:23 PM
Rick's Avatar
Got it back today, they replaced the Antenna ring???
running fine now.
Thanks. all
Old May 11, 2005 | 08:52 PM
The antenna ring is part of the immoblizer system on the car.
Old May 13, 2005 | 02:36 AM
will/bill's Avatar
1.some 2002 and all 2003 up use a bosch style throttle module unlike 99-02 magneti-merelli throttle modules the bosch has been less problematic. ypur car has the bosch. 03
2. the reduced engine performance light will not come on due to a faulty antenna ring (antenna ring is as prevously stated part of the immobelizer system) an antenna ring will not allow communication from the chip in the key to the ecm to start the car. the reduced engine performance message came on due to an other problem
Old May 13, 2005 | 03:03 PM
reg's Avatar
reg
Is it possible to retrofit the Italian throttle body to the newer Bosch??
Old May 13, 2005 | 03:09 PM
Not that I am aware of because it is a totaly different system.
The older was a module itself.
The newer style it just the end of the line it just openes and closes according to the voltage it receives.
Old May 13, 2005 | 04:57 PM
reg's Avatar
reg
What a shame! I guess we are going to be saddled with the Italian piece of garbage. Maybe an aftermarket supplier will come forward??
Old May 13, 2005 | 08:24 PM
Hopefully someone will in the future.
sugardoo
Oct 20, 2013 03:33 PM
etocmo
Aug 31, 2009 07:47 AM
lwrdr2
Dec 30, 2008 01:21 AM
jefflewis1999
Feb 14, 2006 08:48 PM
etocmo
Oct 21, 2004 05:12 PM
