Fifth cylinder misfired…
Old May 6, 2005 | 02:49 PM
robert's Avatar
Default Fifth cylinder misfired…
I have a problem with 1999 S80T6.
The code is “Fifth cylinder misfired”. Dealer said that a compression in fifth cylinder is low. They charge $1000.00 to remove the head and $1000.00 to put it back, plus ~3000.00 for repair.
What should I do in this situation?
Thanks a lot!
Old May 6, 2005 | 08:54 PM
Default RE: Fifth cylinder misfired…
Did they give you the compression numbers?
If so post them so I can look at them.
Are you sure it is not a bad coil?
Old May 7, 2005 | 12:56 PM
robert's Avatar
The coil has been changed. The pressure in the 5th cylinder is 50. All others are around 170-175.
Old May 8, 2005 | 02:35 AM
Did they do a wet compression test after the first one?
That will tell you it if is the rings.
Did they do a cylinder leak down test?
That will tell you if it was the valves.
Old May 9, 2005 | 02:38 PM
robert's Avatar
They didn't do anything.
Old May 9, 2005 | 03:08 PM
Have someone perform the wet down test and the leakdown test and take it from there.That will tell you what you need to do.
4volvoguy
Sep 24, 2012 03:48 PM
trev0006
Volvo C30
Mar 14, 2010 10:22 PM
lmyarana
Oct 1, 2006 09:10 PM
azmark
Jul 21, 2005 11:39 PM
procare
Mar 24, 2005 01:08 AM
