help changing shocks
Old Dec 16, 2007 | 12:09 AM
nickv40's Avatar
Default help changing shocks
need help replacing springs shocks etc on a volvo v40
Old Dec 17, 2007 | 12:28 PM
mcguij1's Avatar
Default RE: help changing shocks
dont do these unless you know exactly what you're doing. You also will need a spring compression tool in order to remove them. Also, make sure to have a wheel alignment done after changing.
Old Dec 18, 2007 | 06:37 AM
nickv40's Avatar
does anyone have directions fro changing shocks out on a v40
Old Dec 18, 2007 | 08:49 AM
mcguij1's Avatar
there are no how to directions. the most luck you would have is under S40concepts.net. But again, unless you've done this before I wouldnt mess with it. You need to make sure your putting the correct shocks/struts on first. What setup are you going with? OEMS or aftermarket?
Old Jan 9, 2008 | 03:02 PM
cbevis's Avatar
Try a Haynes or Chiltons guide. I know....they're typically lacking but Chiltons did fine with the 240.
Old Aug 22, 2008 | 09:35 PM
Rascal2pt0's Avatar
Shocks and struts are fairly straight forward. Elevate and unbolt as whole units. Unbolt the strut mounts, not the struts, you don't do that till their off the car, so you can compress the springs. If you have springs mounted seperate from the struts just make sure the springs are aligned when you drop it back down.
Old Aug 30, 2008 | 02:11 AM
khooper's Avatar
Shock / spring replacement can be a difficult and tedious task, so be sure that you ask help of someone whois also have knowledge on this parts.
______________________
Replacement Shocks
Old Oct 14, 2008 | 08:53 AM
KALIN850W's Avatar
please let a volvo tech do it..dont want a fellow volvo to be in the paper for killing his driver
umbalaxx
May 31, 2015 12:32 PM
PieceKeeper
Nov 26, 2011 08:39 PM
IhateVampires
May 8, 2010 07:12 AM
nickv40
Dec 18, 2007 06:46 AM
parrym
Jul 13, 2007 12:51 PM
