Air conditioning compressor release valve
Old May 23, 2005 | 02:13 PM
skamil's Avatar
Default Air conditioning compressor release valve
I have Volvo S70 98. The air conditioning perform poorly.
The compresor is cicling on and off. When I add 134a, the pressure started to build up and the release valve on the compressor activated, and released the gass. I aded dye, and it spraied from the release valve on the radiator fan, up to the other side of the car.
Can you help?
Old May 24, 2005 | 12:52 AM
Default RE: Air conditioning compressor release valve
It blew out the valve because it was to full or the cooling fan wasn't working and it built up to much pressure.
I know on the older cars once the Valve blows you have to replace it.
Im not sure about the newer ones.I have never seen one on an S70 blow out.
Old Sep 1, 2021 | 09:43 PM
Old volvo owner's Avatar
My 98 s70 is doing the same thing. Easy fix or do I need a new compressor?
Old Sep 2, 2021 | 08:44 AM
Psaboic's Avatar
Suggest taking it to an AC shop. Most likely will require a new compressor as well as system evac and recharge. Just my two cents.
lotekinc
Jul 28, 2016 05:38 PM
I8ASaleen
Sep 20, 2010 09:21 PM
ZeroDormancy
Mar 13, 2009 03:24 PM
rd929
Aug 17, 2008 01:45 PM
chimmychong
May 29, 2008 06:28 PM
