Knocks from under the car while driving
Old May 25, 2005 | 01:48 AM
skamil's Avatar
Default Knocks from under the car while driving
It is S70. When I drive on a bad road, there are knocks from under the car.
I checked the suspensions and they are functioning properly.
What can I check and how?
Old May 25, 2005 | 02:09 AM
Default RE: Knocks from under the car while driving
Check the front upper spring seats.Get a 13/16 wrench and try to turn the top nut under the hood for the front struts.If it turns it is bad.
Also the front sway bar links might be bad.
Old May 25, 2005 | 11:13 AM
skamil's Avatar
Is it better to get struts and susppention from the dealer or after market. What brand is better for S70
Old May 25, 2005 | 02:30 PM
You can go aftermarket for the struts them selves or the links.
Im not sure if the spring seats are avalible aftermarket yet.
Old May 25, 2005 | 04:17 PM
skamil's Avatar
I got Sensa Trac Struts.
The noisy part was the Sway bar link to the struts.
Thank you for the advice.
Belle Tire replaced the Struts and charged labor only $60 for two. Alignment is separate. They did a good job
Old May 25, 2005 | 06:54 PM
Cool im glad you got it fixed.
raomak
Jul 31, 2011 08:04 AM
Big John
Aug 15, 2010 03:06 PM
omniahobo
May 8, 2010 12:24 AM
frank_haren
Sep 26, 2009 06:01 PM
JC
Oct 8, 2005 03:43 PM
