CHECK ENGINE LIGHT
Old May 26, 2005 | 02:44 PM
ANGEL's Avatar
Default CHECK ENGINE LIGHT
98 S70 : For a while the service light would occassional come on, now that went off & check engine light is on..there was a "pump" sounding noise that happen in the winter time. Ran a code search, found out it's the air pump. I'm not hearing the noise anymore. I'm holding off on replaceing it. Is it necessary to replace immediately?? What would happen if I didn't replace it?? Thanks
Old May 26, 2005 | 03:04 PM
Default RE: CHECK ENGINE LIGHT
The air pump help heat the car up first thing in the morning.
You should replace it pretty soon.
Old May 26, 2005 | 05:35 PM
ANGEL's Avatar
What will happen if it breaks on me and how will I know it went? I know these may be silly questions, but I'm glad there is something like this where I can go to, it is obvious that I have no idea..there really isn't someone where I can go that knows about this car, thank you so much
Old May 26, 2005 | 06:59 PM
Your welcome.
If you don't hear it anymore then it isn't working.
2 things happen to the air pump motors.1. Either it fills up with water and shorts out the motor and the relay.
2.The battery leaks and leaks acid onto the motor and shorts it and the relay out.
http://www2.autopartsauthority.com/p...&part=Air+Pump
Here is a company that sells it.It is pretty expensive but cheaper than the dealer.
Old Jun 2, 2005 | 12:42 PM
Air Defender's Avatar
ANGEL,
I replaced the Air Pump on my 98 S70 several months ago. The Tech and I discussed this problem in a previous message:
https://volvoforums.com/m_3175/tm.htm
During my searches online, for a new Air Pump, I discovered that many different merchants were selling the exact same pump (Part # B6010-113076) for a different price dependent on what Volvo model it was listed under. I did a Google/Froogle search for the Part # and found it for $309, instead of the $389 they wanted when I searched for my specific car. Just checked a few minutes ago and I found it for $325. Just wanted to pass this along so that you don't spend more than necessary when looking for parts.
Don't forget to get new hose clamps before you start to replace the air pump. I discovered during my install that the factory clamps are the crimp on one-use kind.
Good Luck.
Air Defender
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
