No Start
Old May 29, 2003 | 12:38 AM
Salvatore's Avatar
Default No Start
I have a 240 DL and I have a no start problem. I know it is a no fuel situation. I have jumped out the fuel/ ing relay 30 and 87-2 they are the red and red with yellow to run the pump and the car starts fine. Went and bought a new relay but this did not solve it. Open the relay and tried to start the car only the ing side of the relay closes. Very unhappy and confused . Please help. Thank You Salvatore
Old Jun 3, 2003 | 07:00 PM
AutoX47's Avatar
Default No Start
So the problem is with the relay, not the fuel system?
Old Oct 24, 2003 | 10:08 PM
Bill C's Avatar
Default No Start
First off; Does this relay supply voltage to the fuel pump?</P>
Is the FUEL PUMP running and producing fuel pressure? </P>
Can you spray carburator cleaner into the throttle body and get the engine to run?</P>
</P><edited><editID>Bill C</editID><editDate>37918.8391782407</editDate></edited>
Old Nov 23, 2003 | 03:58 AM
WizuhD's Avatar
Default No Start
another good question... are the spark plugs getting spark? if not trace it back to where it does and replace bad piece. </P>
i would not advise the use of carblceaner inside the throttle body. it is too hard core of a cleaner to use on the sensitive seals and electronics.</P>
DecalService
Dec 4, 2019 10:52 PM
MMAFIGHTER
Sep 2, 2008 08:43 PM
WagHag
Dec 2, 2007 08:45 AM
auser
Nov 20, 2004 10:27 AM
