Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 02-23-2008, 07:34 AM
tech tech is offline
Default Horn stuck on?
If you happen to have the horn stick on on your car this is what you will need to buy and install.
I have seen a few times that the SRS contact reel is also bad. But 99% of the time it is the steering wheel connections.
It can be purchased here.
http://www.ipdusa.com/Volvo-850/Inte.../p-72-158-548/
http://www.odometergears.com/subpages/volvo.html
http://www.fcpgroton.com/volvo850other.htm
__________________
1995 Yellow T5-RM yes Manual
1996 850 turbo
Old 11-17-2008, 07:28 PM
Adrenalin540 Adrenalin540 is offline
Default RE: Horn stuck on?
Here is a down and dirty way to repair the horn for <$5
Same stuff, do all the safety stuff first...Batt disconnected and get the airbag out of the way, broken parts can be replaced, broken people cannot! SAFETY FIRST. Make sure the car is on a level surface...some airbag switches use Mercury switches that sense vehicle angles and will activate the Airbag...so just play it safe...keep the vehicle level!!!
1. Go to Lowes and get this stuff
http://i312.photobucket.com/albums/l...eceiptcopy.jpg
2. Drill the Horn Brace for the grommet...I put some tape on the drillbit to prevent it from going in to far...
http://i312.photobucket.com/albums/l...DrillBrace.jpg
3. Clean up the mess...also make sure you clean the 'burrs' on the backside of the brace...they are kind of a PITA to get to but be patient...this repair will cost <$5...
http://i312.photobucket.com/albums/l...ir/Cleanup.jpg
4 Identify broken part...it will look like this and the plastic will be broken around the edge...you will see it...
http://i312.photobucket.com/albums/l...BustedPart.jpg
5. Make some homemade washers. I made mine out of an empty milk jug...I used a 12mm socket as the outside template and I think it was a 4.5mm socket for the inside...you only need 2 of these...
http://i312.photobucket.com/albums/l...asherscopy.jpg
6. Put the washer around the grommet and work it in place from the back side towards the front...it goes in pretty easy...
http://i312.photobucket.com/albums/l...ackforward.jpg
7. Work the grommet in place with a fine jewlers screwdriver...if you don't have one any fine pointed object will work, just DON'T mess up the grommet...
http://i312.photobucket.com/albums/l...ewlerssc-1.jpg
8. You can follow Techs advise from here forward...pretty simple.
9. The only addition I may want to add is do NOT OVER TIGHTEN THE NUT on the backside! once it is snug...I put some 'GORILLA GLUE' on the backside to prevent it from coming loose... Pretty simple repair...<$5
__________________
93 Volvo 850 NA
94 Volvo 850 NA
95 Frod Probe
99 BMW 5401-6
99 Jeep GrancCherokee Ltd
Tags
2000, 740, 850, 94, 940, 960, broken, contact, horn, install, location, reel, s80, stuck, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
