brakes on a 2007 volvo v50
Old Feb 23, 2008 | 09:52 PM
hollywood's Avatar
Default brakes on a 2007 volvo v50
i have a problem with my brakes almost going to the floor on this car with only 4,000 miles. anyone got any idea why this might happen.
Old Feb 24, 2008 | 06:54 AM
JPN's Avatar
JPN
Default RE: brakes on a 2007 volvo v50
Moved from New Members Area. Notified the original poster.
Welcome to the forum.
Your car is very new and the only reason I can think of is manufacturing defect. If the brake pedal goes to the floor, it is usually a sign of air begin introduced into the brake system. Have a reputable shop bleed the system to see if the brake functions properly. If bleeding the brake fluid does not solve the problem, I can only assume that the master cylinder could be faulty. A car with many miles could have this symptom due to worn out pads/rotors but your car only has 4,000 miles so this one is probably out.
I would find an independent shop that specialises in Swedish/Euro makes and have a certified ASE Master Technician work on your car. Insist on using DOT-4 brake fluid. Or, you can visit a dealer; dealers charge more but they usually do the job right the first time.
I hope other V50 owners come in, but if you did not receive other replies quick enough, post this question in General Volvo Chat.
Best of luck,
JPN
Old Feb 25, 2008 | 03:56 PM
reg's Avatar
reg
Could be a vacuum issue in the booster................
r.
Old Mar 17, 2008 | 11:38 PM
Bigtrev's Avatar
Don't waste your money going to a shop other than the dealership the car is still under warranty. They should be able to find out what the problem is. With a major safety item like that I am sure they will know what the problem is when you get there.
Old May 24, 2008 | 03:58 PM
mncx's Avatar
There is a recall just release for the master cylinder. Dealer should have been informed already they may replace your brake booster if it's soak in brake fluid. Recall #194
patricklaw7
May 4, 2014 01:51 PM
santoury
Apr 2, 2014 08:28 AM
Shabobo
Sep 4, 2009 11:52 PM
Shabobo
Aug 6, 2009 08:15 PM
monEmakindave
Feb 1, 2008 06:43 PM
