Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo XC70
Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 03-13-2008, 08:43 AM
johnhon johnhon is offline
Default HOW TO REPAIR TIMING BELT HEAD GASKET BENT VALVES
After bending the valves on my 1998 V70XC engine due to an incorrect timing belt installation, I decided to tackle the job of rebuilding the head on my engine. Being a carpenter, I decided to make some of the tools required for removal/assembly out of wood with what I had lying around my shop. Overall it was a good experience and I learned a lot about my car. None of it was very difficult, but I'm glad I'm a patient guy.
After disconnecting the necessary items in the engine compartment I removed the head assembly out of the car along with the turbo and exhaust manifold attached. My small Kubota backhoe was perfect for lifting it out of the engine compartment and putting it back in. Anything I took off I put in baggies and labeled them.
With the head off I could see the damage the intake valves did to the pistons. There were some very slight indentations on the exhaust side of some of the pistons but I replaced only the intake valves. Exhaust valves weren't damaged.
Not a very pretty picture.
A moment when I was trying to find the humor in all of this...
This was my valve spring compressor tool. I made this out of an old birch spindle I had. The taper of the spindle allowed me to fit it into the valve recess perfectly. I cut the fork on one end to compress the valve springs with a 12" C-clamp and remove the valve retainers with a small magnet. The recess in the other end of the dowel was perfect for seating the valve guides with the tap of a hammer
Valve guides installed
I took the head and intake manifold to a shop and had them clean everything. I installed the lower end of the head with the turbo attached. Whenever I could I replaced anything that was going to be hard to get to later (ie vacum lines, o-rings, thermostat) and also took apart the turbo to clean it.
Don't forget the turbo oil seal!
I made the camshaft holders out of Poplar and glued slotted dowels onto the Poplar after the cams were aligned correctly on the upper part of the head. The next day I drilled locations for screws to hold the camshafts in place.
Spreading the volvo gasket
Installing the head by gently clamping with wood clamps to compress the valve springs. Now I could start putting everything back together. I took a lot of pictures along the way so I wouldn't forget the order of certain items. The only thing I forgot to do was to tighten one of the banjo fittings running off the turbo into the block. I ended up with a puddle of oil under the car but I consider that not too bad.
I made sure that when I put the timing belt on the this time I turned the engine over by hand a few times, check the timing marks, turn over a few more times, then crank it over. You should have seen the smile on my face when it started.
If anyone needs any help on something I didn't cover in enough detail feel free to post or email me. Good luck and have fun!
__________________
1998 V70 XC AWD Turbo 155,000 mi - Green
1998 V70 XC AWD Turbo 165,000 mi - Silver
1997 850 wagon 117,000 mi - Teal
1995 Mercedes E320 wagon 163,000 mi - Gray
Old 03-13-2008, 09:31 AM
Psaboic's Avatar
Psaboic Psaboic is offline
Default RE: HOW TO REPAIR TIMING BELT HEAD GASKET BENT VALVES
WOW!!
Great Pictures. I think this should be made a sticky at the top of this section.
__________________
2002 VW TDI 105K (mine)
2001 XC 70 100K (hers)
1995 850 Turbo 205K (kids)
1965 Corvair Corsa 96K (ours)
Old 03-13-2008, 08:33 PM
tech tech is online now
Done
__________________
1995 Yellow T5-RM yes Manual
1996 850 turbo
Old 04-09-2008, 05:53 PM
JRoc JRoc is offline
Johnhon, email sent!
__________________
01 s60
Old 01-05-2009, 11:52 AM
TCRIMSONK TCRIMSONK is offline
Hi, I just signed up because I'm dealing with this exact same problem. I've got a '98 V70XC that threw a timing belt, and don't want to pay a shop to replace the valves. Only two of the valves appear to be bent. Am I the only one who can't see Johnhon's images?
Old 01-05-2009, 12:35 PM
Something must be wrong with link.
__________________
1996 850 turbo
Old 01-06-2009, 02:30 AM
Setting up the timing is tricky on theintake cam due to the hydraulic variable timing on it. Also, when you take in the cylinder head to have the valves replaced, bring the valve cover as well. They need to resurface the mating surfaces of the valve cover and cylinder head, otherwise it'll leak oil when its all back together. there is no valve cover gasket...
__________________
01 s60
Old 01-06-2009, 04:03 AM
JRoc, I'm 90% sure I've got the non VVT style engine, the gear on the end of the intake cam looks exactly like the one on the exhaust cam.
I appreciate the heads-up on the leaking cover, and was wondering if I was crazy not finding a gasket when I took it apart. I'm actually planning on replacing the valves myself, which isn't conducive to having them resurfaced. If you like, check the thread I started HERE.
I'll probably end up cleaning the surfaces and spraying some Copper Gasket Adhesive on the mating surfaces, unless you guys don't think that will work.
Old 01-06-2009, 08:54 AM
I would use the Volvo stuff it is pretty expensive but is awesome stuff.
__________________
1996 850 turbo
Old 04-15-2009, 03:05 PM
roadster roadster is offline
Default need some help
hi john, i have the same car with the same issues and just wondering if you could give me a hand with some issues on setting up the cams.. i have the tools, but have never done a vvt motor, and looks like you have some good advise. if you could email me with some help that would be great, thanks
Tags
2001, affect, belt, bent, fix, gasket, head, pictures, repair, s40, timing, tool, v70, valve, valves, volvo, xc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
