Replacing Stock Air Filter (86 760 T)
Old Jun 22, 2005 | 03:55 AM
Totti's Avatar
Default Replacing Stock Air Filter (86 760 T)
Hi guys,
I recently bought a pod filter to replace the standard one in my 760T. However, after undoing the clips and lifting up the housing, it looks like the Air flow meter and the panel filter are all intertwined.
Does anyone know if i'd be able to install this pod filter in conjuction with the AFM? Im just not sure if someone the filter can be completely lifted out and replaced with a pod.
Cheers
Old Jun 22, 2005 | 10:52 AM
Default RE: Replacing Stock Air Filter (86 760 T)
There is screws inside the top cover to remove the air mass meter.
Then remove the entire air filter box and install the cone filter.
You might have to make a bracket to help support the filter.
debargha
Feb 24, 2015 10:46 PM
olesy1064
Oct 25, 2011 08:04 PM
fifa12
Jun 16, 2010 12:56 PM
Jabber
Feb 4, 2009 02:14 PM
