coil over convert
Old Mar 23, 2008 | 02:28 AM
joey99's Avatar
Default coil over convert
just went thru my stuff, found my set of jic coil over ,beautiful camber plates , for myskyline , and i think i will install them on my 850t5, imessured the fronts, and minor fitting is going to be required , but will work even thelength is the same just got to weld a bung for the stab link , the rears are almost the same length , but i will have to take the springs out ,andmachine holders, for the springs, i was going to copy the kw coil over set up to be able to adjust the ride height will post some photos soon
Old Mar 23, 2008 | 08:59 AM
Default RE: coil over convert
Please do I want to see this.
RGHamilton57
Jun 29, 2015 08:22 PM
Ricardito
Aug 14, 2012 08:29 PM
vol70
Jul 18, 2012 10:51 PM
