Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 03-23-2008, 10:44 PM
pittpan2005 pittpan2005 is offline
Default A how to for PCV system for beginners
If you stop by the mechanic because you have oil on the top of the engine, under the spark plug cover, or smoke is coming out of the dip stick, they will probably tell you your crankcase ventilation system is shot. They will then say its between $600-$800 to replace it. Say thanks, but I can do it myself. I am fairly new to working on cars, escpecially volvos, but found the system to be easy to replace, for the most part. I did it on a 95 850 turbo. 3 weeks ago I had no idea what a PCV system was, but through this site I found out and knew my car needed it replaced. In 12 hours I had it done. If you follow my tidbits of advice a newbie could be done in 8 hours.
1st go to fcpgroton.com and order the correct system for your car. Order the whole system, except for the expensive intake hose unless your car needs a new one. Order a EGR valve gasket and throttle body gasket while your at it. Also order all knew gaskets/seals for your fuel ignitors. There are 4 per ignitor, totalling 20. You can do it without new ones, as long as your willing to scrub them with a soft bristled brush and use mechanic style soap you use on your hands. No dish detergent. They will clean up, but when you take the injectors out you may lose a few seals, that why I would buy all new ones. Also buy a mixed assortment of hose clamps to replace all hoses, unless you want to use the ones that come with your order. They are the standard volvo ones that are a pain in the neck. Once you have all these parts its time to begin.
The system runs from underneath your intake manifold, up over to the top of the engine, and around the engine block to the rear into the turbo. 1 hose connects to the manifold itself, 1 into the top of the engine, under the spark plug cover, and 2 around the side of the engine into that large hose behind the engine. That hose is "accordian instrument" like. It does not need to be taken off unless you want to.
To start, take out the battery, airbox, and unhook all hoses in your way. Drain the engine coolant, you'll find out later if you forget to do it. Behind the engine is that large black hose that has the 2 lines connected to it, which are part of the PCV system. Unhook those 2 lines. I believe there is an electrical connection on it as well. They are connected to a weird shaped plastic part that needs cleaned. It can be pulled out of the large hose, but can be difficult to put back in. If you need to take the hose out completely and clean that piece, but make sure you reinstall it before you start hooking up the new system. Otherwise you will crack your new hoses. It just pushes back in place. OK now that you made some room its time to move on. Take off the spark plug cover and unhook that black hose running through the manifold into the top of the engine.
Next you need to unhookthe fuel injector rail. The top piece is pushed in place. It will pull of. It is the 1st piece of metal covering the ignitor wires. Then unboltthe lower piece, but do not remove. The fuel lines need loosened first. The lower piece, fuel ignitor rail, is held in place by 2 bolts. Unhook the electronic connections (5). There are 2 fuel lines running from up behind the engine on the passengers side. There are 1-2 bolts holding them in place. Remove them. There is also a clamp that holds them together. They are the 2 black narrow lines connected to the top of the engine.
Now you need to remove the ignitors which are connected to that metal ignitor rail. You can use the special tool to remove them together, or just pull as evenly as you can. This is when you will lose your ignitor seals. Take all 5 ignitors out, clean the seals, or replace them. The seals go as follows. The uppermost goes in the fuel rail, its a flat seal, like a washer. It sits above the ignitor. The next seal is a donut, goes on top of the ignitor. The third goes on the bottom of the ignitor, also a donut, same seal. The 4th is placed inside the manifold where the bottom of the ignitor goes in. Its a larger, round seal. I will explain how to install the top seals when you reasseble later. Once you have removed the ignitors from the rail, place the rail on top of the engine. If you loosened the fuel lines it should move enough so that it sits up out of your way to remove the manifold.
Next unhook the throttle cable, remove that pulley, and remove the throttle body. Clean it good while your at it. They are on the front of the engine to the drivers side if your not sure. There are like 8 bolts. Take notes of how everything goes in. Lots of hoses, etc. Underneath is the EGR valve. It is connected to a large gold pipe. It is a royal pain in the neck, but get it off however you can. DO NOT BREAK IT!!!!! $200 to fix. Its the weird shaped valve held to the manifold by 2 longbolts, very strange looking bolts. DO NOT BREAK!!!! I did.
Now take out the thermostat to allow you to gain access to all the manifold bolts. If you forgot to drain the coolant your about to make a mess. The thermostat is located on the passenger side next to the manifold. The engine coolant resevior tank hose connects to it.
Now its time to remove the manifold. There are 2 bolts underneath holding the bottom of the manifold in place. 1st is the bolt connecting the dip stick to the manifold and the 2nd is just above it. You can feel them both from reaching underneath the manifold from on top. Or you can see them from underneath the car with a flashlight. I found it easiset to remove them with a 1/4 ratchet from on top by reaching under the manifold. I hope you have smaller arms. Once these 2 bolts are removed remove all the manifold bolts. I think 7 on top. This part can be painful. Do not forget about the bolt in the corner that the thermostat was hiding.
Pull out the manifold. In order to do so you need to have removed that black hose running through it up over into the top of the engine. There is a thin hose connected to the side of the manifold from the PCV system. Remove it. Clean the manifold and be sure to have a new gasket.
Now you can see the whole PCV system. It starts with that black box and has a few hoses connected to it. 1 to the manifold, 1 up over to the top of the engine, and 2 around the engine to the large hose in the back. Be delicate, they will break. You simply install the new stuff just as you found it.
Now reassemble. Do not forget to run that black hose through the manifold up over to the top of the engine. Also there is the thin hose connected to the passenger side of the manifold. Connect the lower 2 bolts to the manifold 1st. If you do the top 1st, youll have to take it off later. Now insert the new manifold gasket. Put 2 bolts through the manifold and gasketto hold the gasket in place. Now push the manifold into place and screw a few bolts in to even it out. Tighten them all as neccessary. Have a magnet ready for dropped bolts. The hardest bolt is the one in the corner behind where the thermostat was. I recomend duct taping the bolt to a strong magnet and inserting it and getting a few threads in. Once its not going to pop out, take off the duct tape and finish tightening it up. Now keep reassembling.
Thermostat, egr valve, throttle body, pully.
Now the ignitors. Use a slite bit of vasoline on the washer shaped seal for the top of the fuel rail if the seals wont stay in place. I recommmend putting the top seal in, then the injector. Do it 1 at a time. 1 seal, 1 injector into the rail. 2nd seal, 2nd injector into the rail, etc. Now install all 5 injectors connectedto the railinto the manifold. Make sure there sitting nice and even. Connect the electrical connections, bolt the rail, and install the upper piece of metal over the electrical wiring. Dont forget about that thin
Old 03-24-2008, 09:23 PM
tech tech is offline
Default RE: A how to for PCV system for beginners
Great post thanks!!
__________________
1995 Yellow T5-RM yes Manual
1996 850 turbo
Old 03-26-2008, 09:19 PM
jbourque jbourque is offline
just did mine on a 98 XC and was able to skip many steps, left injectors and throttle linkage attached to intake and just rotated up and back. also no need to drain coolant or remove thermostat, thankfully they must have relocated some of these items. also on mine you don't need to remove lower bolts, just loosen as intake is slotted on bottom, very handy. wish I had read your post first, I followed directions I read somewhere else and they did't mention that other bolt underneath intake just behind dipstick bolt, I had all bolts out or loose (or so I thought) yet couldn't lift off intake, finally found it after feeling around to see what was still holding it. Repair has reduced the oil puddling on top of engine, but not totally elimanated it, so I don't know what else I can do? New oil cap?
__________________
98 XC
94 SL500
04 Silverado SS
82 Fuego Turbo
Old 03-26-2008, 11:15 PM
The lower bolts on the manifold do not need to be removed!! Of course I didn't realize that until after the fact. I am not the person to give much advice, but I will tell you what I heard. Over time from overpressurization it makes sense for all the seals to gradually loosen or weaken. It happens from regular heat and weather so why wouldn't overpressurization cause it to happen quicker? I think the mechanic had a good point, but not worth replacing all the seals in the engine to me. I replaced the oil return line gasket and o-ring. Wow did it need it, and the PCV system. I am still getting some smoke when I pull the dipstick, but I am hoping that will dispate with time. Maybe old oil, etc burning off. There is a gasket that you can buy for the oil cap. I would change that out.
Luke
Old 03-29-2008, 10:46 AM
JaneBriefcase JaneBriefcase is offline
I really wish this thread had pictures.
Old 03-29-2008, 09:41 PM
Some basic pics of the parts needed to remove in order to take the manifold off.
Old 03-29-2008, 09:59 PM
The files were to large. I will keep working on it. They will be up soon.
Old 04-01-2008, 04:52 PM
Zimbo Zimbo is offline
Poking around and found this thread.
I did a write-up with pictures, hope it helps.
PCV Write-up
-Rob
Old 01-27-2010, 09:45 PM
kman3786osu kman3786osu is offline
Default Thanks ron
wow, incredible write-up, you should do professional manuals.
__________________
lee t moraca
Tags
850, 960, clean, fuel, hose, howto, injector, manifold, pcv, pics, rail, removing, replacing, seals, system, unhooking, volvo, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
