SRS light - How to reset?
Old Jul 4, 2005 | 01:54 AM
elbert's Avatar
Default SRS light - How to reset?
I worked on the dash and subsquently remove the passenger air bag connector. I had to run an errand in between the work and the SRS light went off, as it should, since I did not have the power connector to the unit on. Later after working on the dash, the SRS light still is staying on although I'm abosoulety sure I connected it back on properly. I tried disconnecting the battery for an hour and wiiggled the connector to make sure it is plugged on properly. To no avail, the SRS light is still on. How do you go about resetting the SRS light?
Thank you in advance for your any assistance!
elbert
'98, S70, 110K
Old Jul 4, 2005 | 02:09 AM
Default RE: SRS light - How to reset?
You will have to find someone that has a scanner that reads SRS codes and clears them.
Old Jul 4, 2005 | 02:46 AM
elbert's Avatar
Is the SRS scanner code different from the OBDII engine light scanner code reader?
Old Jul 4, 2005 | 02:58 AM
You have to look closely at the scanner and the papers.Alot of the ones sold will only do check engine lights.
Some will do transmission codes as well.
Most of the time you will have to spend quite a bit of money to get one that does everything.
copterrob
Jun 22, 2021 10:12 PM
MSP850T
Apr 6, 2020 06:51 PM
marvgt95
Dec 28, 2009 05:14 PM
cava
Jul 29, 2006 12:27 PM
JimKW
Jul 26, 2006 08:49 PM
