wet seat belts?
Old Jul 14, 2005 | 12:55 PM
blac70's Avatar
Default wet seat belts?
so in the us does the recall cover 2001? my car just went out of warranty in april..............
i expereince both of those problems.............
water leaks from the seal at the back window.
the stealership held my car untill the warranty expired while repairing this, had a big problem with them so i am not willing to go back to them to get it readjusted(plus i moved a couple hours away so long drive too). different dealer maybe?
Old Jul 14, 2005 | 04:40 PM
reg's Avatar
reg
Default RE: wet seat belts?
The c70 is the most expensive auto that Volve sells...............................but the warranty is just as abysmal as the 40 series. I highly suspect that Volvo will not retroactively honor the seat belt issue! I do not have that problem with mine although I have very few miles on the auto as I use it as my winter beater and airport 'parker'. I truly expect to keep mine for several more years as I do enjoy the appearance................I simply swallow when I take it to the dealer..............which is more often than either a Japanese or German auto.
Old Jul 21, 2005 | 10:30 PM
If they just worked on them then you should have a 12/12 warranty on what they just did.
davidwhitt
Jan 11, 2008 11:42 PM
rcoonce
Dec 2, 2007 09:51 AM
topdwn
Nov 2, 2006 11:01 PM
billofdurham
Feb 11, 2006 03:27 PM
Daz_C70
Jul 12, 2005 06:29 PM
