Starter bad? '90 760 gle
Old Jul 16, 2005 | 06:01 PM
jlorgan's Avatar
Default Starter bad? '90 760 gle
I went out this morning and the car won't start. The battery seems fine, I don't have any way to test it. The car will make one click when I try to turn it over and nothing. I'm thinking the starter is bad. Any tricks I should try before I have is towed to the mechanic?
Old Jul 21, 2005 | 10:38 PM
Default RE: Starter bad? '90 760 gle
Sounds like the starter to me.
Old Jul 25, 2005 | 08:25 PM
jlorgan's Avatar
Recap:
I went out later that day and tried again. Got the single click, and then it turned over. It's been running ever since with no problems other than occasionally it will turn over more than usual before starting. Any ideas what I can expect to die in the near future? Alternator, starter is on the way out, maybe it is the battery?
Old Jul 25, 2005 | 09:41 PM
Ignavus's Avatar
Try removing , cleaning and re-installing both connections at the battery and see it it helps.
Old Jul 25, 2005 | 09:45 PM
If it happens again try tapping the starter while someone holds the key on.Then if it works the starter will need to be replaced.
86volvoguy
Apr 20, 2017 10:50 PM
TrouperL
Oct 20, 2010 08:01 PM
spawl
Dec 11, 2005 09:03 PM
jlorgan
Jun 30, 2005 06:06 PM
volvo_girl
Sep 18, 2004 07:50 PM
