760t greyish white smoke
Old Jul 17, 2005 | 04:18 AM
cool_guy_jay's Avatar
Default 760t greyish white smoke
i have a 760 TI any thick grey white smoke is coming from the exhaust, is it a head gasket problem or something else?
Old Sep 26, 2005 | 03:02 PM
FredDC's Avatar
Default RE: 760t greyish white smoke
You are probably sucking oil through the turbo seal. Is there oil in the air intake or intercooler pipes?
Did you try a compression test? No comp in any cylinder would mean blowby pressure is pushing pressure into the lower engine and squezzing oil out where it can.
This is often death,
Old Sep 27, 2005 | 10:35 PM
forrestkk's Avatar
Could be a head gasket, what does the smoke smell like? If it smells sweet it is a head gasket. You can also verify by opening your coolant resivoir and rev the engine a small amount. If you see air bubbles it's a head gasket. You will see water flow in the coolant tank but if it's air thats bad.
If the smoke is a grey with a bluish tint. It could be oil. I don't know about all Volvos, but turbos somtimes blow the seal that isolates the bearing from either the impeller or compressor. That will use a ton of oil and it will smoke like nobodies business.
volvoyoungster
Nov 16, 2006 12:25 AM
85 760Turbo
Feb 16, 2006 10:13 PM
85 760Turbo
Feb 13, 2006 09:52 PM
dmccorquodale
Dec 7, 2005 07:06 PM
cool_guy_jay
Jul 17, 2005 04:22 AM
