where car thinks the trunk is open
Old Jul 22, 2005 | 12:45 AM
BlackDiamondBound's Avatar
Default where car thinks the trunk is open
when driving the trunk light comes on randomly. then it will turn off. and it does that the whole time i drive. anyone know if there are sensors some where that might need to be tightened down?
Old Jul 22, 2005 | 01:04 AM
Default RE: where car thinks the trunk is open
You will most likely need to have the trunk latch assembly replaced.
The switch is located inside the latch assembly.
Old May 23, 2006 | 06:14 PM
durangokid's Avatar
I replaced the trunk latch assembly, but, the dash light is still on. Any suggestions?
Old May 23, 2006 | 09:02 PM
If you close the Latch manually does the light go off?
If not then look at the wiring diagram and try to track it down.
http://www.volvotechinfo.com/WD123/
I forget what year yours is just click on your year on the list.
athelmiller
Apr 3, 2011 05:10 PM
Vincef
Mar 18, 2009 08:42 PM
axelm
Mar 10, 2007 06:30 PM
JimmyzVolvo
Jul 25, 2004 05:32 AM
