How to replace gear position sensor?
Old Aug 31, 2008 | 12:28 PM
mason3325's Avatar
Default How to replace gear position sensor?
I have 1998 S90. I need to replace the gear position sensor because I got transmission codes P0715 and P0705. Where is the gear position sensor located? Any suggestions on replacing gear position sensor by oneself? Thanks.
Old Aug 31, 2008 | 10:21 PM
Default RE: How to replace gear position sensor?
The gear position sensor is on the passenger side of the transmission. There is 1 12MM screw holding it on. Also loosen the big nut on the PNP. The plug goes up over the top of the tranny. When you install the new one hook an Ohm meter to the red and blue wires and make sure that it that beeps and make sure it is beeping when you tighten the bolt.
That will make sure it is set correctly.
Old Sep 2, 2008 | 07:57 AM
mason3325's Avatar
ORIGINAL: tech
Thanks for the info. I have never touched S90 tranny before. Could you give me a little bit more details of the procedures. Some one told me that I have
to first remove the battery and air filter box. But some other one told me that that is for Volvo 850.
Old Sep 2, 2008 | 06:23 PM
Yes thats for a 850. Like I stated above yours is on the side of the transmission. The tranny is under the car. The PNP switch is on the passenger side.
Old Oct 18, 2008 | 02:22 PM
mason3325's Avatar
Hi, Tech, thanks for the tips. I removed the 12mm screw and the 22mm big nut. The PNP switch now can rotate, but cannot be pull out.
Any tips for pull it out? Do we need any specical tools to pull out the switch? Thanks.
Old Oct 18, 2008 | 09:25 PM
Sometimes it is a major pain due to rust on the shaft.
true grit
Apr 28, 2015 11:51 AM
fetalinjury
Dec 17, 2012 11:11 AM
king831
Dec 15, 2011 11:14 PM
bomba
Jun 22, 2008 09:36 PM
petes99xc
Feb 10, 2007 10:24 AM
