Check Engine Light on 98 V70XC
Old Aug 8, 2005 | 01:12 PM
tkarttrev's Avatar
Default Check Engine Light on 98 V70XC
Hello, I am the proud owner of a used 98 V70XC and I like the car a lot, got it for the wife and the little girl. I am currently trying to work my way through a "Check Engine" light issue and would appreciate any insights that forum members may have. From what I can gather, this is not uncommon, so I appologise if I am beating a dead horse, but...
The code I get when I scan the ODB is "P0455: Evaporative Emissions Control System Leak Detected (Gross Leak)"
I have replaced several questionable vacum lines, the gas cap, reset the light but it comes back on. I realize that there are a host of things that can cause this code (charcoal canisters, vac lines, fuel tank, etc) but I am looking for any insight that forum watchers may have.
Thanks in advance. Trev
Old Aug 8, 2005 | 10:00 PM
Default RE: Check Engine Light on 98 V70XC
Try getting a new Evap valve and filter.The Evap valve is located on the cooling fan shroud.
Also make sure you follow every line and check it really good.
Old Aug 8, 2005 | 10:36 PM
tkarttrev's Avatar
Tech,
Thanks, I will do just that as a bunch of people have mentioned the valve you suggested. Seems like you are very helpful to the group and have a lot of knowledge, Thanks in advance, Trev
By the way, for fun, check out what we do in the backyard at www.grasspass.org
Trev
Old Aug 9, 2005 | 01:09 AM
That is so cool.
Keep me posted on what happens with the car.
Old Aug 5, 2006 | 06:49 PM
azeezn's Avatar
Hey tech, by filter did you mean fuel filter? Thanx!
Old Aug 8, 2006 | 12:54 AM
No they sell an inline Filter for the Evap system it goes on the back side of the Valve.
tngreg
Sep 5, 2022 07:27 PM
bcolins
2001-2013 model year V70
Oct 13, 2013 10:44 PM
ErnstlS90
Oct 23, 2008 08:37 AM
jklenk
Aug 18, 2008 12:26 AM
llama_of_doom
Aug 23, 2007 09:52 PM
