Service message, oil filter location
Old Sep 2, 2008 | 07:54 PM
Jeff_si's Avatar
Default Service message, oil filter location
Normal 0 MicrosoftInternetExplorer4 Style Definitions table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Proceed as follows to reset the service reminder indicator (SRI):
- Ignition off
- Press and hold in the reset button for the trip odometer Ignition on
- The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
- Release the reset button for the trip odometer within 4 seconds . The instrument gives an audible signal when the reset has succeeded. The SRI indicator lamp goes out.
NOTE: If the reset button for the trip odometer is not released within 4 seconds , the light is not reset. However it will stop flashing.
Straight from the Volvo Service manuals
Oil filter is located left front of engine compartment, as you are standing in front of vehicle lookinginto the engine. It requires a 36mm socket for removal, have to remove (3) part air intake first (2 screws).To drain oil, must remove stone guard underneath engine (6 torque screws). Jack up car from passengerside, drain plug located in the middle on the side of drain pan (note plug on the back side).Should use new crush washer for drain plug and new rubber O-ring for oil filter.
How info is of use.............Best Jeff
Old Nov 9, 2008 | 07:49 PM
Pearsonmx6's Avatar
Default RE: Service message, oil filter location
make sure to loosen the oil filter before draining the oil there is a check valve under it, and will prevent you from draning all of the oil.
et3_quade
Sep 18, 2007 08:04 AM
aair65
Oct 17, 2006 01:28 AM
mingster
May 8, 2006 11:54 AM
logisusa
Jan 22, 2006 06:34 PM
n2umr
Feb 12, 2005 06:23 PM
