Rear shock replacement on c70 convertible
Old Aug 11, 2005 | 11:28 PM
oconnomo's Avatar
Default Rear shock replacement on c70 convertible
Hello,
I have a 2000 c70 convertible and need to know how to get to the rear shocks. I pulled apart the trunk, but the shocks look like they mount closer to underneath the rear seat. Can anyone tell me the best way to get to them????
Old Aug 12, 2005 | 09:47 PM
Default RE: Rear shock replacement on c70 convertible
I forget if you have to remove the rear seat or not.
It has been a long while since I had a rear seat out of a C70.
I thought you could access from the trunk.
Old Aug 13, 2005 | 11:26 AM
oconnomo's Avatar
Tech,
I'll look in the trunk again to make sure, but they line up with the rear seat back. I tried to remove the seats to take a look, but could'nt get them out. I didn't want to break anything. I figured I'd ask before I went yanking on the seats. I'll have to gently figure out how to get the seat out........
Old Aug 13, 2005 | 11:52 AM
If I remember correctly there is 2 buttons you will have to push in the front of the seat bottom to get it to release.
Then you will have to reach up under the rear seat back and press some tabs to release the headrests(You will need someone to help you remove them) Then you will have to slide the seat from the seatbelts.
Old Aug 13, 2005 | 06:12 PM
oconnomo's Avatar
Tech,
Thanks, I'll give that a try. I will let you know how it turns out.....
Old Aug 13, 2005 | 09:25 PM
reg's Avatar
reg
Are you positive that you need a shock replacement on a 2000 Volvo???
Old Aug 20, 2005 | 12:44 AM
oconnomo's Avatar
Tech & Reg,
I replaced all struts and shocks today. The mounts for the rear shocks were behind the rear seat, as previously thought.
The shocks were shot. I could compress them and they did not extend once released. The ride is "Like New"..... The struts were probably O.K., but I replaced them since I purchased everything in a package deal. Thanks for the help.....
Oconnomo
Old Aug 20, 2005 | 12:55 AM
glad you got it going!!
Old Apr 20, 2009 | 05:02 PM
Dex2020's Avatar
Default I need to Replace rear struts on my C70 convertible
Originally Posted by oconnomo
Tech & Reg,
Oconnomo
Hello, could you tell me how you got the rear seat out of your C70 I can not find any latches or bottons and need to replace the rear struts. Thanks
Old Apr 20, 2009 | 05:06 PM
Dex2020's Avatar
Hello, How did you get the seats out of your C70 I need to replace my struts but can not find any bottons or latches and need to replace my struts. Thanks, Dex
Old Apr 22, 2009 | 06:33 PM
MoneypitC70's Avatar
I have a new set of rear shocks sitting in my trunk because I could not figure out how to remove the rear seat...and 2 shops refused to do this work. How does the rear seat come loose?
Old Aug 6, 2009 | 06:18 PM
VolvoMike941's Avatar
Default Rear Shock replacement instruction C70 Convertible
I pulled the back seat out, but could not find the top nut of the rear shock.
What am I doing wrong?
Old Aug 6, 2009 | 06:23 PM
Default C70 convetible rear shock replacement
I got the bottom of the rear seat out using a interior 2 blade screw driver, left over from my other Volvos.
Stick the interior screw driver type device under the bottom front of the rear seat and it lifts out, then pull out the bottom of the rear seat forward, remove from the car.
Then lower left and right side of the back of the rear seat are two 14mm nuts, unscrew one on each side.
That's as far as I got, because I still could not see the top nut of the rear shock absorbers. So I put it back together.
Old Aug 7, 2009 | 06:08 AM
cb1313's Avatar
Thumbs up rear shocks
I did my 2003 C70 convertible two weeks ago. Pull up on the rear seat corners, there are no bolts holding the bottom of the seat. THERE ARE 2 bolts that hold the back seat down, one in each corner. Swing the seat all the way up, there are some clips at the top, push the seat back and the rear seat can be remove. There are clips inside the back seat holding the headrest, reach inside of back seat, push and pull headrest at the same time and remove before trying to remove seat.
There are holes covered by foam, 2 large, 2 small. remove foam and there are the tops of the shocks.
I have 25 years of Aircraft (air force, boeing) and have never seen any designed so poorly. It took me 4 hours just to figure out how/what tools to get the darn nuts off. If your vice grips are worn go get a small new one. that was the only tool I could find to fit and get a wrench in the small space.
OR I REPEAT OR .... with the car on jacks, and a block of wood, pillows and blankets you can loosen the nut with the spring tension on the shock and the nut should have enough tension nut to let the shock shaft spin.
This is not SAFE ,,,, but it worked for me. DO NIT TRY THIS WHEN INSTALLING THE SHOCKS !!
INSTALLING...... after the shock is installed I put some large washers on the top mount bolts so the locking nut did not have so many threads to tighten.... BUT.... make sure you do have enough for the locking nut to tighten... OR YOU WILL BE BACK TRYING TO TIGHTEN THAT NUT.
Replacing the foam.... I went to Low's and found some air conditioner wrap the is sticky on one side and recovered the holes.
I am not sorry for all spelling erors or missing words.... I am only on my 6th cup of coffee and it;s 6 in the mornig///////////
Need any help.... please contact me ?
Cb
Old Aug 7, 2009 | 02:05 PM
Thanks CB1313,
I also called my Volvo dealer, who advised to remove the rear speakers behind the back to the back seat to access the top of the rear shocks.
VolvoMike941
greenman86
Apr 25, 2014 09:47 AM
jared..mann
1998-2000 model year V70
Apr 20, 2013 04:33 PM
paul1149
Sep 6, 2012 11:20 AM
940turbo94
Nov 29, 2007 09:39 PM
