Steering and Gas
Old Sep 19, 2008 | 07:56 PM
rmac2001's Avatar
Default Steering and Gas
Hello,
I recently got the rack and pinion replaced on my car after a soft/tough turn issue. After the repair the steering is fine but the steering wheel is a little off ( I have to correct the wheel to right). When the car is in park the steering wheel and tires are aligned and straight... the correction occurs when I drive. The mechanic looked at it again and said it was straight but I still have the same problem. Does anyone have any suggestions... is this a big deal?
Also, does anyone use gas other than premium in the S90? Have you had any difference in performance with using a different grade of gas?
Thank you in advance.
Old Sep 19, 2008 | 08:09 PM
Default RE: Steering and Gas
Did they align the car after the rack install?
Old Sep 19, 2008 | 08:21 PM
rmac2001's Avatar
Yes... I took it back and they did it again.
Old Sep 19, 2008 | 08:27 PM
Make them do it again to straighten the wheel.
Also on the gas try to use premium as much as you can. The 960/S90 are known to burn valves.
You should be fine switching every other tank.
tian6869
Oct 18, 2012 05:28 PM
Joanna
Apr 3, 2008 05:36 PM
dman777
Jan 23, 2008 12:08 AM
jollygoodgold
Jul 16, 2007 12:06 PM
JeremyR
Aug 3, 2006 05:36 PM
