Aftermarket head unit wiring
Old Aug 30, 2005 | 07:54 PM
matthewensey's Avatar
Default Aftermarket head unit wiring
I'm installing an aftermarket head unit in my 88 240 because the radio sucks with the stock head unit. Here's the wiring description for the Volvo wiring:
Orange/white stripe: +12v
Black/White: Ground
Red: Left/Rear speaker+
White: Left/Front speaker+
Yellow: Right/Rear speaker+
Blue: Right/Front speaker+
Black: Speakers-
Green/White: Clock
OK. On my after market head unit, there is one negative wire for each speaker. As opposed to just one speaker negative wire on the volvo harness. How do I connect those wires? Also, on the aftermarket, there is a +12v Memory wire, is that the clock? I'm assuming it is. Thanks for any help you can offer!
Matthew
Old Aug 30, 2005 | 10:11 PM
Default RE: Aftermarket head unit wiring
Why not just stop by a local electronics shop and buy the adapter for like $15.00.
Then that will eliminate all the problems.
BTW:The memory wire is for the clock and to keep all your stations.
Old Aug 30, 2005 | 11:05 PM
Thanks. I think I'll just go the adapter route.
Old Aug 30, 2005 | 11:13 PM
Keep me posted!!
Old Aug 30, 2005 | 11:44 PM
Will do..........
Old Aug 30, 2005 | 11:56 PM
.................................................. .photo test.............................................. .....
Old Aug 30, 2005 | 11:58 PM
There we go. Got it. OK. Please ignore the last few posts.
LOL.
Old Aug 31, 2005 | 12:43 AM
LOL
Old Aug 31, 2005 | 12:50 AM
Alright, that's enough of that......crap...............
I didn't notice the signature image option until earlier.
Old Nov 9, 2005 | 11:00 PM
mbaker's Avatar
if a remember correctly you cant just buy a wire harness. volvo is a very odd car to do this kind of stuff with. there is am amp that you have to by pass befor the head unit will work. unfortunantly i have never wanted to F*** with the volvo like that so i have always had the guys install it for me. sorry i couldnt be of more help
mike
Old Dec 29, 2005 | 01:27 PM
birdman's Avatar
Hey Matt, how were you able to get this to work? I'm having the same problem. I purchased this adaptor from Scosche, but the wiring doesn't line up at all. So I pulled the leads out of the plastic head so I could stick 'em where I *thought* they belonged, but still no luck.
Here's the Scosche factory adaptor:
And here's how the wiring in my factory harness looks:
I've tried every which way to put them together, with no luck. Any pointers?
Incidentally, what / where is this mysterious amp that may be causing me trouble?
cmhswim25
Dec 7, 2010 06:00 PM
Justin Mason
Apr 16, 2009 03:26 PM
Tompoirier6
Apr 6, 2009 11:21 PM
Tompoirier6
Apr 3, 2009 12:31 AM
illegal driving
Jan 11, 2006 12:46 AM
