Aftermarket Rims/lowering
Old Aug 31, 2005 | 06:00 PM
AZ960's Avatar
Default Aftermarket Rims/lowering
I need some advise.
I have a 96, 960 sedan, does anyone know what the max rim size is that will fit??
If you have put rims on yours let me know what size and if any other mods were necessary (i.e. spacers, fender adjustment)
There is a bracket that holds the front coil spring which sits about a half inch off the top of the front tire, does that prevent a larger diameter wheel?
Has anyone tried to lower a 960? I dropped $300 on soime b+g springs, only to discover that there are no springs on the rear end, only a single "plastic" leaf spring. Can the coils replace the leaf in any way? or am i screwed?
Old Aug 31, 2005 | 09:31 PM
Default RE: Aftermarket Rims/lowering
Not to sure about the rims.
But you are screwed on the springs.
Did you specify the year of your car when you ordered them?
Dex2020
Feb 7, 2019 02:21 PM
Pej
May 14, 2012 03:52 PM
jbooker82
Oct 19, 2011 05:25 AM
drjaymez
Aug 14, 2011 08:12 PM
850alex
Oct 16, 2009 10:39 PM
