Penta Discuss Volvo Penta Marine Machines Within.
4.3 GL changing Thermo stat
Old Dec 24, 2008 | 10:22 AM
werv2go's Avatar
Default 4.3 GL changing Thermo stat
I have a 4.3 GL and the water temp gauge is not working or reads very low. I assume this is a Thermostat problem. So I'm thinking about changing the thermostat, but not sure of the procedure. Any step by step guide would be appreciated or what should I troubleshoot first before changing out the t-stat. Thanks
Old Dec 26, 2008 | 06:24 PM
850GLTWAGON's Avatar
Default RE: 4.3 GL changing Thermo stat
Well first you need test the gauge
to do that you want to find the sender on the motor, usally right next to the t-stat
turn the key on and ground out the sender
if it reads full, your gauge is ok
i might be your sender
urdrwho
Mar 9, 2014 01:50 PM
mattn888
Oct 23, 2011 08:57 PM
jenny
Nov 4, 2010 11:05 PM
drzvolvobob
May 30, 2009 06:40 AM
aruizdelhoyo
Jan 22, 2009 04:46 PM
