Radio dead
Old Dec 24, 2008 | 11:42 AM
mgreen2's Avatar
Default Radio dead
My battery went dead and I had a tow service jump it off. I had to replace the alternator and also had a fusedlink that was bad. When I got the car back the radiowas not working and I had a warning light on about the ABS. Not sure if it was a jolt from the jump or some other cause.
I found a fuse to the ABS wasblown, replaced it and no further problem. I checked the fuses to the radio under the dash and all are good. Is there a fusable link that effects the radio or some other fuse I am missing? Thank you!
Old Dec 24, 2008 | 12:20 PM
billofdurham's Avatar
Default RE: Radio dead
Fuses 9 and 18, which you have checked, and an in-line fuse to the CD changer are all I can find on the wiring diagrams. I don't know whether the in-line will stop the radio but it is on a green/grey wire out of terminal 4 on the radio.
Old Dec 24, 2008 | 04:03 PM
mgreen2's Avatar
How would I get access to the wires on the back of the radio to check the fuse?
Thank you.
Old Dec 24, 2008 | 04:31 PM
On the fascia of the radio at either side near the bottom you will see two push in catches. Press on these and they will come out of the fascia. Now pull them further out and use them to pullthe radioout of the dash.
press270
Jul 22, 2010 08:22 AM
cchapdu1
Jan 7, 2010 10:24 PM
RobGrant
Jun 18, 2009 02:45 PM
zmontgomery
Oct 20, 2008 12:18 AM
BigAdam
Aug 24, 2008 03:18 AM
