clunking noise on my 240
Old Sep 5, 2005 | 05:09 AM
Red XC's Avatar
Default clunking noise on my 240
Since when I bought the 245. The LF always have a clunking noise going over bumps. I know its the suspension or the control arms. I heard that it might be just the bolts loose or overtighten from ipd technical advice? please help tech or any1!
Old Sep 5, 2005 | 12:16 PM
Default RE: clunking noise on my 240
Look at the rear of the lower control arm where it meets the body.There is a round bushing that mounts in a bracket that bolts to the body.Two things happen the bushing breaks and makes noise or the bushing slide inside the bracket making noise.
Also check the balljoint.
Old Sep 7, 2005 | 10:47 AM
cranky's Avatar
Good call tech..... I had the same problem with a 240, and it was exactly the bushing you mentioned, and it was doing exactly what you said - sliding around inside the bracket. $39.95 and I was on my way.
The bushing is the one closest to being underneath the drivers seat, and was quite easy to change. One more thing, the noise would generally cease under braking conditions.
Cranky
Old Sep 9, 2005 | 01:27 AM
Red XC's Avatar
thanks ill check on that! i replaced the balljoints after I bought the car. And noise was still there.. so I'll go inspect the bushings.
Old Oct 22, 2005 | 02:19 AM
Red XC's Avatar
the bushings look fine.. any other ideas tech?
Old Oct 22, 2005 | 11:58 AM
Just look everything over really good and try moving things with a pry bar and look for excessive movement on bushings.
brians46236
Sep 24, 2008 10:11 AM
tenchu
May 12, 2008 10:09 PM
leebae
Mar 26, 2008 06:59 PM
ice queen
Jan 16, 2008 02:58 PM
m1964
Feb 3, 2006 12:32 AM
