93 850 Failed Smog
Old Mar 10, 2004 | 09:28 PM
tassadar30's Avatar
Default 93 850 Failed Smog
Recently i had a valve job done on it. They resurfaced the upper head as well. After getting everything back together, It ran. The engine light was still on, but i figured it was because i never reset it. About 800-1000 miles later I checked the codes and recieved "missing or bad o2, missing or bad MAF". I reset the ecu (A2) and drove it around, then cheked for faults in A2. I found none. When I took it in for smog I failed Hydrocarbon(max=85 meas=102) at 15mph, but passed at 25mph. I've read that O2 sensors can go bad and be undetected by the ecu. It has seemed to lose power on acceleration, but i thought maybe 'cause it had 140k mi on the engine. Should i try to clean the MAF and O2 sensors? How can I be sure they're in working order? What else should I look for?</P>
</P>
Old Apr 23, 2007 | 10:42 AM
Rev's Avatar
Rev
Default RE: 93 850 Failed Smog
I would try and cleaning the intake tract, throttle body with SeaFoam, checking PCV valve as well.
Old Apr 23, 2007 | 11:07 AM
JimKW's Avatar
If the O2 sensor is bad, you have to replace it. There is no cleaning for that.
scorpioneyes
Apr 22, 2007 11:21 AM
HelgaTheS80
Feb 24, 2007 12:57 PM
joanvito
Sep 28, 2006 09:19 PM
dynomac
Sep 24, 2006 12:12 AM
tassadar30
Jun 22, 2004 01:16 AM
