high-pitched whining noise
Old Mar 28, 2004 | 06:26 AM
cetaphil's Avatar
Default high-pitched whining noise
<DIV id=intelliTxt>
<DIV>I've been driving the <NOBR>Volvo</NOBR> S60 2.0T LPT (light-pressure turbo) for 2.5 years now.
Recently for the past few days, I notice that whenever I start driving and depressing the accelerator pedal, a strange high-pitchedwhining sound appears. This is different from the usual rumbling low-pitched engine sound. This high-pitched sound gets louder and more high-pitched when I depress the accelerator pedal more; it becomes softer and less high-pitched, then disappears when I release the pedal. If the car is stationary and the gear is put to "P" and not "D", the high-pitched sound does not appear when I depress the accelerator pedal.
The service consultanat at the Volvo dealer said that this high-pitched sound is due to the turbo or turbine engine - wear and tear is the given reason. There is no way to remedy the sound unless the whole turbo is replaced, which costs me few thousand dollars.
</DIV>
<DIV>However, there are other reasons cited by others in the internet from various sources as to the cause of this "turbo sound" including intake hose, muffler, turbo bearings, exhaust pipe, intake plenum. But some say that this is a transmission problem due to worn out pinion bearings, some say it is due to worn out crank pulley or idler pulley.</DIV>
<DIV>
Is this high-pitched sound really due to the turbo? Or is it due to transmission orsomething else? Does that mean that cars with no turbo will not have this problem and those with turbo will definitely experience this after few years due to wear and tear? How to remedy this problem?
Can anyone help?
Deeply appreciated.
Thanks.
Regards. Cetaphil</DIV></DIV>
Old Aug 2, 2004 | 03:52 PM
pilotsims's Avatar
Default RE: high-pitched whining noise
call me crazy but have u checked your belt tension. there is a small chance that the belts are slipping causing a high pitched whine. it makes sense that when u accelerate, the belt noise will get louder. it has happened to me and even if it isnt the belt, it is worth checking.
Old Mar 23, 2009 | 07:55 PM
ANITAP39's Avatar
Default high pitched whining noise
Hi, I don't have a turbo and my 2004 S60 is making the same sound just like you described. We don't even know where to start to know what is wrong. Did you find out what was causing your noise? Thanks.
Old Mar 23, 2009 | 07:56 PM
ANITAP39's Avatar
Default whining noise
Also, we replaced the belt first and it still makes the noise.
Old Mar 23, 2009 | 08:06 PM
Did you replace the timing belt and tensioner and idler?
Old Mar 23, 2009 | 08:10 PM
ANITAP39's Avatar
Hi and thanks for helping. We replaced the timing belt, tensioner and idler around 100,000 miles. Our 2004 S60 has 170,000 miles on it now.
Old Mar 23, 2009 | 08:13 PM
ANITAP39's Avatar
Actually, today, it made the sound while in park before even putting it into gear or accelerating. That is different from what the #1 post said above.
Old Mar 23, 2009 | 08:25 PM
Check the idler and tensioner agian it might be bad causing the noise.
Old Mar 23, 2009 | 08:27 PM
ANITAP39's Avatar
Thanks. We will try that.
M363P
Sep 30, 2011 08:15 AM
s40sedan
Jun 14, 2011 05:14 AM
volvovera
Jan 12, 2011 01:37 PM
arhood
Oct 27, 2009 02:17 AM
