1998 XC70AWD 2.5 Barometric Sensor
Old Sep 18, 2005 | 04:38 AM
mspcrjcapt's Avatar
Default 1998 XC70AWD 2.5 Barometric Sensor
Hi all.
I had a check engine light that came on and the dealer said it was the barometric sensor. They want an arm and a leg for it. I need to see if anyone knows where to find one cheap, and where exactly it is located so I can change it out. I am going to sell my baby for a new one and I am sure the new owner does not want any idiot lights on.
If you need any further info, e-mail me at mspcrjcapt@comcast.net.
Ed
Old Sep 18, 2005 | 10:17 PM
Default RE: 1998 XC70AWD 2.5 Barometric Sensor
The baro sensor os mounted to the front of the subframe on the right side of the car.
Alot of times the high pressure switch for the A/C is the problem not the baro sensor.
Old Sep 19, 2005 | 01:10 AM
mspcrjcapt's Avatar
Is it the small black Bosch (approx 1 inch X 2 inch) right behind the headlight? Where is the H/P switch for the A/C located? Is there any way to isolate the problem?
Thanks again for the time you spend with all of us.
Ed
Old Sep 20, 2005 | 01:12 AM
The high pressure switch is located on the end of the A/C line behind the right side headlight.In front of where the fill port is.
I really haven't fault traced that much and isolated other then trying a new switch. That was the best part of working at the dealer.
rparker
Nov 19, 2013 03:50 PM
trooperone
Dec 21, 2009 11:45 PM
volvorecycle
Oct 2, 2009 12:19 PM
LowEnergyParticle
Apr 9, 2009 10:09 PM
Qamar
Aug 6, 2005 12:07 PM
