Alternative for Nivomat
Old Mar 6, 2009 | 09:05 AM
Panoramix's Avatar
Default Alternative for Nivomat
Because I use my V70 for heavy loads from time to time, I'd like to install some Nivomats, in order to keep the car level under every load condition. Ordering them as an OEM set will cost approx $1000. This includes the additional hardware (softer springs etc.).
I' am wondering if there is a, not so expensive, alternative, such as air pressurized shocks or bellows which will fit in the springs.
Any suggestion would be welcome.
BTW it is a 07V70 2.5T
Old Mar 12, 2009 | 08:26 PM
TIPSP's Avatar
Got Boost?
Tech might know.
Old Mar 20, 2009 | 05:42 AM
Typhoon's Avatar
If the coil springs do not have teh shocks running inside them then you can easily fit and run airbags in the car. I install them , very easy to fit and are the best way to have a car that rides well unloaded but can handle a good load when the bags are pumped up.
A 4" lift is very acheivable with airbags and it doesn't put big loads on the shock mounts like air shicks do.
Regards, Andrew.
daver80
Apr 5, 2011 01:21 PM
RonnieBgood
Mar 20, 2011 05:58 PM
tkarttrev
Sep 10, 2009 01:22 PM
pilot60378
Sep 29, 2006 10:15 PM
snoboarder_mike
Jul 2, 2006 10:55 AM
