I think my heater core is shot
Old May 9, 2009 | 11:53 PM
VJZ's Avatar
VJZ
Default I think my heater core is shot
Today I used the A/C for a while on a trip.
Pulled into a CVS parking lot to go get a card for my mom.
Came out and there was a trail of coolant.
Seems to be leaking underneath the middle of the car.
Passenger side floor is also damp.
Could it be JUST the core? Or what else could be.
Seems like a fairly straightforward process. I won't be using the heat or A/C til this is fixed.
Old May 10, 2009 | 08:36 AM
Did it smell like coolant? It the bottle low?
It could have also been dye from the A/C.
Old May 10, 2009 | 10:18 AM
VJZ's Avatar
VJZ
no its definitely coolant.
I had to fill it up last night.
Now there is a puddle from overnight under the passenger side of the car.
Floorboard does smell like coolant
Old May 10, 2009 | 10:20 AM
VJZ's Avatar
VJZ
oh yeah...it also did it when I used the heat last night when It got cold out
Old May 10, 2009 | 10:41 AM
Well the heater core always has coolant going through it. There is no heater control valve.
For now you can bypass it or get a new one and replace it.
Old May 10, 2009 | 11:04 AM
VJZ's Avatar
VJZ
How do I bypass it?
I'll do that until I sell the SC and pick up a new core, hoses and grommets.
We had to do that on my buddies 92 Celica about a month ago.
Old May 10, 2009 | 11:18 AM
Remove the hoses where they go into the firewall. You have to press the clips in then pull the lines out. Then use a piece of hose and join the 2 hoses.
Old May 10, 2009 | 01:44 PM
VJZ's Avatar
VJZ
Which hoses?
It looks like there's a few there.
Old May 10, 2009 | 02:26 PM
There is 2 that go into the firewall like just above the turbo. Those are the heater core hoses.
Old May 10, 2009 | 06:52 PM
VJZ's Avatar
VJZ
Yeah i'll have to pop those off tomorrow and get bigger hose.
Hey also, how hard is it to put the oil lines to the radiator on? I think I'm going to get new ones from someone and do the car right.
Old May 10, 2009 | 06:54 PM
They are kind of a pain but take your time and you will be fine.
Old May 11, 2009 | 11:01 PM
VJZ's Avatar
VJZ
What size hose is it to loop the HC lines?
Old May 11, 2009 | 11:03 PM
Sorry I do not know the exact size I had a piece in the garage when I had to do mine while waiting for parts. There was no marking on the hose for size.
Old May 12, 2009 | 03:41 PM
VJZ's Avatar
VJZ
Okay so, I ordered my heater core today.
Car Quest here in town gets in ACTUAL Volvo heater cores
Do I need to order new heater hoses as well?
I know I need those rings, but I don't know about the hoses.
When the leak started, I noticed the underbody leak first. Then I checked the pass. side floor board.
Old May 12, 2009 | 08:35 PM
You do not have to disconnect the lines outside to replace the core.
Old May 13, 2009 | 09:41 AM
VJZ's Avatar
VJZ
I don't know what happened to that post. I meant to ask if I should order new heater lines since there was a leak under the car? I know I need those seals.
Old May 13, 2009 | 08:50 PM
I would fix the heater core first then go from there.
Old May 14, 2009 | 03:10 PM
VJZ's Avatar
VJZ
I had the car running today, and it started to leak under the engine towards the firewall.
From up top everything is dry and I can't figure out where it is coming from.
Should I order those gaskets for the heater core job before putting this one in?
I can't figure out why it could be leaking.
It runs and drives fine, so I don't think its the head gasket.
When I look under the car, there are some metal pipes on the bottom that are doused in coolant from something leaking on to them.
Should I just replace the core and see if the leak stops?
Old May 14, 2009 | 06:58 PM
I would maybe it is leaking out of the A/C drain area. That is like under the dash.
Old May 27, 2009 | 04:00 PM
VJZ's Avatar
VJZ
I'm back kind of.
I sold my SC and picked up my 76 Celica.
But, the 850 is still leaking.
Today I decided to drive it after it being parked for about a week and a half.
Fired right up and drives fine.
The car is still leaking coolant from underneath somewhere.
I bought the heater core, and am ordering stuff from FCP as we speak.
Since have the heater core in my possession, what other parts from FCP should I order?
Additionally, it appears that the coolant leak is coming from underneath the area near the turbo.
I do not see any coolant on the firewall.
Could this all be simply a hose running to the turbo?
I guess I'm still confused as to why it could be the heater core if it leaks like crazy underneath the car.
It happens with the A/C on or off as well along with the car being parked.
I can't see it being a head gasket. I had it sitting in the McDonalds drive thru for a good ten minutes along with giving it a little Hell around town. It does NOT overheat. The A/C blows cold still and it idles and drives great.
What should I do?
