Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 05-18-2009, 09:58 PM
Supra850 Supra850 is offline
Send a message via MSN to Supra850
Default 1997 Volvo 850 Non turbo automatic radiator write up
Mods please Sticky
1997 Volvo 850 Non-Turbo Automatic Radiator write-up
Alright, so had a radiator leak, here is the walk through of the rad replacement. ALL DIRECTIONS ARE FROM STANDING AT THE FRONT BUMPER FACING THE WINDSHIELD. (LEFT IS PASSENGER) (RIGHT IS DRIVER)
This is what I started with:
1. Jack the car up either on sides or front cross member although I did notice the cross member bend slightly:
2. Axle stands on front mounts (triangular in shape with 3 bolts LCA?)
3. Drain Anti-freeze out of drain plug (bottom right side) Hint:Unscrew the overflow tank cap (usually blue near passenger side strut tower)
13MM socket, should be fairly deep:
4. Remove upper/lower radiator hoses (tops are 10 MM socket, bottom is 8MM)
5. Remove this panel, I believe it was two 10 or 11mm bolts on the BACKSIDE of the panel on both pass/drive side.
6. Remove this mount for a vacuum line, right side of the radiator two (away from my head right now, not phillips but the actual "Star" shaped bit torx?)
7. There is also a vacuum line on the block, mine broke, I could not get the clamp off.
http://s321.photobucket.com/albums/n...t=P5170268.jpg
Unhook the vacuum line and remove this electical connection:
7.b Should turn out like this:
http://s321.photobucket.com/albums/n...t=P5170267.jpg
8.On the fan should there are a few Electrical connections you have to unhook:
Old 05-18-2009, 10:00 PM
PART B: 1997 Volvo 850 Non-turbo automatic Radiator Write-up
(This is on the back of the panel you removed earlier)
9.The shroud should lift out with some ease, just be careful with any other connections that may get caught in it.
10. Now you have to take the transmission cooler (smaller radiator infront) off the large radiator. There are four (4) bolts holding the radiator to the t. radiator 10MM and they are on all four corners of the t. radiator.
10.A Passenger:
10.B Driver:
11.Lower drivers side (through mesh grille)
12. Now I put a jack under BOTH radiators just to support them (I was alone doing this so two jacks helped)
13. I then removed the transmission coolant lines. There are two, one on the top and one on the bottom on the drivers side of the radiator:
TIP: Have TWO (2) drain buckets, one for any excess anti-freeze that comes out of lower rad hose, and minimal out of the TOP transmission line, then move that out, get another smaller bucket and put it directly under where the lower rad hose would go (hose hookup?) transmission fluid WILL spill out and will contaminate the anti-freeze.. making it useless:
13.B These clips will most likely break on you, be careful:
13.C Top/Bottom lines:
14.Now double check to make sure the transmission radiator is free from the engine radiator, and both are supported by something stable a jack worked fine for me (Car on axle stands, floor jack under engine rad, scissor jack under transmission rad) Then double check to make sure all lines are free from both radiators (esp engine rad)
15. Then remove the two bolts holding the engine rad in place, you have to be on the ground looking up to get these.
On left and right side of the rad:
Drivers side:
I want to say these are 12MM bolts x2 and they are pretty long bolts
Now slowly lower the jack make sure you put the floor jack under the engine rad because its alot easier to lower it.
Now, slowly lower the jack, trying to support the rad as best as you can, shouldn't be too hard I did it alone. Then once the jack is depressed, go to the top of the car and slowly and carefully lift it off, and lower it to the ground, resting it gently at an angle on the ground. The two mounts for the bolts you removed at step 15 should catch on something so it won't go too far.
If you can get a spare set of hands one person go under and guide it to the floor, again I did it alone with no damage to any component. Lower the rad until its parallel with the ground (completely free of the car) then pull it out.
I then pulled out the new radiator, and re-installed it. Plugging the old radiator with rags to make sure it doesn't leak, and put it back in the box the new rad came in:
Now, for re installing, I got help to guide the new radiator back into place, again underneath the car guiding on an angle back into place. Put the two bolts back in from the bottom (step 15) and then re attach the transmission radiator, electrical lines, fans, transmission oil lines trim panels and you're done.
I have left the 850 on jack stands, its may long weekend here in Canada and Volvo was closed I am going to get new transmission oil line o-rings and the clamps and "volvo radiator fluid" will finish tomorrow. Might as well leave the car up on the jack stands because the angle the car is on will get air pockets in the coolant out when you re-fill the radiator.
Old 05-18-2009, 11:02 PM
tech tech is offline
Thanks I made is a sticky.
__________________
1995 Yellow T5-RM yes Manual
1996 850 turbo
Old 05-20-2009, 12:20 AM
kockyhardrockr kockyhardrockr is offline
Send a message via AIM to kockyhardrockr
Unhappy
Awesome write up. would have saved my $400
__________________
93-97 Turbo Automatic, coming soon
96' Burgundy Volvo 850 Automatic - 225,000 - Dead.
Blown head gasket, cv boots, shocks, struts, pcv system.
Old 07-12-2009, 09:11 PM
VTBricked VTBricked is offline
Correction on part identification (not procedure): the "transmission cooler" in front of the radiator is the air conditioning condenser.
Caution/expectation on removing radiator bolts. Rust (especially in northern states using salt in the winter) will make removal difficult. Sometimes the threaded part attached to the car will break free and you're looking at visegrips or similar tool to hold it while you remove the bolt.
__________________
'00 V70R
'00, '99, '98 (2) XC70
850 sedan
Old 10-02-2009, 03:12 AM
mikeross mikeross is offline
This is a great volvo radiator write up. I should have read it. I really had difficulty removing the radiator bolts..
Old 10-19-2009, 01:33 AM
lovely09 lovely09 is offline
A great write up for a more clear procedure.It's perfect as i need to do this on weekend.I will study how you do it and work on by myself.
Tags
1997, 850, 97, block, drain, florida, installing, leak, line, plug, radiator, support, turbo, vacuum, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
