How do you know which ECU will work for you?
Old 06-15-2009, 09:16 PM
Philly240's Avatar
Default How do you know which ECU will work for you?
Is there a series that only works for certain years of 240's? Are they Model specific? What do you look for to make sure it'll work for your volvo, what do you need to know? I plan on going to a junk yard to find a replacement ECU for my 91 240 and don't wanna get stuck with one that's no good for my car.
Old 06-15-2009, 10:10 PM
TIPSP's Avatar
Got Boost?
Your 91 will have LH2.4 so you will want to find a LH2.4 ECU/ICU.
IF you are turbo'd, then you will need to find a turbo ECU/ICU.
IF you are NA'd, then you will need to find a NA ECU/ICU.
Also keep in mind if you have EGR...etc.
Read carefully.....
This list was taken from Fredrik over at Turbobricks.com (this is from the chipping FAQs Some ECU might not be listed)
LH2.4
240 Saloon (P242, P244) - 2.3 i CAT 08.88-07.90 115HP B230F
240 Estate (P245) - 2.3 i CAT 08.88-07.90 115HP B230F
EZ 116 K (Ignition ECU):
0 227 400 140
0 227 400 169
All EZK´s are not "chippable". You have to open them up to check for a chip-socket on a daughter card mounted on the motherboard.
These EZK´s are not suitable for turbo or F+T without "chipping".
240 Coupé, Saloon (P242, P244) - 2.3 i CAT 08.88- 115HP B230F
240 Estate (P245) - 2.3 i CAT 08.88- 115HP B230F
740 Estate (745) - 2.0 08.89-07.91 112HP B200F
740 Saloon (744) - 2.3 08.88-07.90 115HP B230F
740 Estate (745) - 2.3 08.88-07.90 115HP B230F
0 227 400 146
0 227 400 169
740 Saloon (744) - 2.3 08.89-07.90 151HP B234F
740 Estate (745) - 2.3 08.89-07.90 151HP B234F
740 Saloon (744) - 2.3 08.89-07.90 156HP B234F
740 Estate (745) - 2.3 08.89- 156HP B234F
740 Saloon (744) - 2.3 04.88- 159HP B234F
740 Estate (745) - 2.3 04.88- 159HP B234F
940 Saloon (944) - 2.3 09.90- 156HP B234F
940 Estate (945) - 2.3 09.90- 155HP B234F
0 227 400 152
0 227 400 119
0 227 400 147
740 Saloon (744) - 2.3 Turbo 08.89-07.90 165 B230FT
740 Estate (745) - 2.3 Turbo 08.89-07.90 165 B230FT
780 Coupé - 2.3 Turbo 165-190HP B230FT
LH2.4 (Fuel ECU):
0 280 000 563
(LH2.4.1 - Volvo p/n: 3517370, 5003787)
0 227 400 149 - EGR
760 Saloon (704, 764) - 2.3 Turbo 08.89-07.92 162 B230FT
LH2.4 (Fuel ECU):
0 280 000 560 - EGR
0 986 261 744 - recon. part, EGR
(LH2.4.1 - Volvo p/n: 3517368, 5003786)
0 280 000 563
0 227 400 149 - EGR
940 Estate (945) - 2.0 Turbo 01.91-07.95 155HP B200FT
LH2.4 (Fuel ECU):
0 280 000 596
0 986 261 762 - recon. part
(LH 2.4.1 - Volvo p/n: 3531721)
0 280 000 932
0 986 261 809 - recon. part
0 986 262 708 - recon. part
(LH2.4.4 - Volvo p/n: 3547772, 5003832)
0 227 400 117
940 Saloon (944) - 2.3 Turbo 08.90-07.94 165 B230FT
940 Estate (945) - 2.3 Turbo 08.90-07.94 165 B230FT
LH2.4 (Fuel ECU):
0 280 000 563
0 280 000 937
0 986 261 813 - recon. part
0 986 262 709 - recon. part
(LH2.4.4 - Volvo p/n: 1271895, 3547781, 5003837, 8601059)
0 280 000 954
(LH2.4.4 - Volvo p/n: n/a)
0 280 000 967
0 280 000 939 - EGR
0 986 261 814 - recon. part
0 986 262 705 - recon. part
(LH2.4.4 - Volvo p/n: 3547783, 5003952, 9135138, 9146219)
940 Mk II Saloon (944) - 2.0 Turbo 04.96-10.98 155HP B200FT
940 Mk II Estate (945) - 2.0 Turbo 04.96-10.98 155HP B200FT
LH2.4 (Fuel ECU):
0 280 000 979
(LH2.4.4 - Volvo p/n: 1275202, 8601146)
0 280 000 980 - Immobilizer
0 280 000 981 - Immobilizer
(LH2.4.4 - Volvo p/n: 1275467, 8601148)
0 280 000 932
940 Mk II Saloon (944) - 2.3 Turbo 01.95-10.98 135HP B230FK
940 Mk II Estate (945) - 2.3 Turbo 01.95-10.98 135HP B230FK
LH2.4 (Fuel ECU):
0 280 000 977 - Immobilizer
0 986 262 706 - recon. part
(LH2.4.4 - Volvo p/n: 1270539, 8601215)
0 280 000 962
0 986 262 707 - recon. part
(LH2.4.4 - Volvo p/n: 8601218, 9135591)
0 227 400 207 - EGR, some models only
0 227 400 219 - Some models only
940 Mk II Saloon (944) - 2.3 Turbo 08.94-10.98 165HP B230FT & FT4
940 Mk II Estate (945) - 2.3 Turbo 08.94-10.98 165HP B230FT & FT4
LH2.4 (Fuel ECU):
0 280 000 983
0 280 000 984 - immobilizer
(LH2.4.4 - Volvo p/n: 8601361, 9125465, 9179343)
0 280 000 962
740/760/940/960 - 2.0 16V Turbo 190/200HP B204FT/GT
LH2.4 (Fuel ECU):
0 280 000 597
0 986 261 763 - recon. part
(LH2.4.1 - Volvo p/n: 3531519, 5003776)
0 280 000 578
0 986 261 754 - recon. part
(LH2.4.1 - Volvo p/n: 3517718, 5003775)
0 280 000 926
0 986 262 702 - recon. part
0 986 262 711 - recon. part
(LH2.4.4 - Volvo p/n: 3507258, 3547059, 5003826)
0 280 000 950
(LH2.4.4 - Volvo p/n: Should be interchangeable with 0 280 000 926)
0 227 400 159
0 227 400 208
LH2.4 non-turbo
740 Saloon (744) - 2.3 08.89-07.90 151HP B234F/G
740 Estate (745) - 2.3 08.89-07.90 151HP B234F/G
740 Saloon (744) - 2.3 08.89-07.90 156HP B234F/G
740 Estate (745) - 2.3 08.89- 156HP B234F/G
740 Saloon (744) - 2.3 04.88- 159HP B234F/G
740 Estate (745) - 2.3 04.88- 159HP B234F/G
940 Saloon (944) - 2.3 09.90- 156HP B234F/G
940 Estate (945) - 2.3 09.90- 155HP B234F/G
LH2.4 (Fuel ECU):
0 280 000 549
0 986 261 738 - recon. part
(LH2.4.0 - Volvo p/n: 1367065, 5003789)
0 280 000 562 - EGR
0 986 261 746 - EGR, recon. part
(LH2.4.0 - Volvo p/n: 3507605, 3517372, 5003794)
0 280 000 571
0 986 261 751 - recon. part
(LH2.4.0 - Volvo p/n: 3507604, 3517608, 5003793)
0 280 000 911
0 986 261 805 - recon. part
(LH2.4.2 - Volvo p/n: 3547262, 5003792)
0 280 000 928
0 986 261 807 - recon. part
0 986 262 700 - recon. part
(LH2.4.3 - Volvo p/n: 3547788, 5003840, 9146218)
0 227 400 152
0 227 400 119
0 227 400 147
Old 06-16-2009, 03:26 AM
Philly240's Avatar
Thanks TIPSP
Old 06-16-2009, 10:22 PM
soundmiami's Avatar
Look on the on you have, it probably ends in 561, match those numbers up and you're good to go. They are plug and play so test it before you leave. There are issues with moisture getting into one of the chips over time even when not in use, so store it somewhere dry.
Attached Thumbnails How do you know which ECU will work for you?-1992-240-ecu.jpg
Old 06-23-2009, 03:52 PM
Philly240's Avatar
I've heard that you can use the 951 series ECU to replace the 561 is this true?
Also what if anything will happen if you try a 951 instead of a 561 in the car?
I have the pink label 561 ECU that I hear is rumored to fail and be replaced by the white label ECU.
Old 01-07-2011, 09:44 AM
sloughin's Avatar
Default Which ECU for 1993 940T Wagon?
I've got the old unit out and it is BOSCH 0-280-000-937
My parts supplier tells me that the 1993 940T Wagon takes either
0-280-000-563 (w/EGR)
or
0-280-000-967 (w/o EGR)
I had guessed I would need the 563 and ordered it thinking I had a 50-50 chance, but when I took the old unit out it didn't match either possibility. When I look up 937, one post said it goes with the earlier 740 model.
I'm told that to look for the EGR I have to go under the car, but I don't have any jack stands handy, so any advice you have would be helpful.
rspi
12-05-2012 12:44 PM
autoTRADER
03-15-2012 10:36 AM
nitrosport
02-14-2012 01:28 PM
hbgray
07-24-2008 03:41 PM
skadet
12-06-2005 08:53 PM
Quick Reply: How do you know which ECU will work for you?
