1998 Volvo S70 Shifter Problems
Old Apr 23, 2004 | 12:56 PM
Kordax's Avatar
Default 1998 Volvo S70 Shifter Problems
I am having problems with the shifter on my S70. When I park the car I have to hit on the shifter a little to get it to go into park. This doesn't happen all the time. Another problem I am having is that I cant get the key out of the ignition for about 30 seconds. I am sure this has to do with the fact that the car is not in park. Has anyone else had this same problem and what did you do to fix it. Thanks</P>
Old May 24, 2004 | 09:41 PM
DrewG1998's Avatar
Easy. Get a manual.
Old Jun 16, 2004 | 12:17 PM
piperjay's Avatar
I had a similar problem with my '98 S70</P>
It was the button on the shift ****. The spring wasn't functioning properly. So after depressing it to shift, I had to manually push on the top of the button to get it to spring back and lock into park. Only after it locks in, can you remove the key.</P>
I am certain this is your problem.</P>
xDread92x
Jul 21, 2019 04:18 PM
rspi
Feb 10, 2013 05:02 PM
rspi
Sep 5, 2012 10:45 AM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
