THROTTLE POSITION SENSOR (TPS)
Old Oct 20, 2005 | 11:34 AM
DENNISVHANK's Avatar
Default THROTTLE POSITION SENSOR (TPS)
CHECK ENGINE LITE (CE LITE) CAME ON... I CHECK THE CODE 1-2-3.... I REPLACE THE TPS, RESET CE LITE.. A DAY LATER IT CAME ON AGAIN, I CHECK THE CODE, SAME THING, IT CAN GO UP TO A COUPLE DAYS BUT THEN IT COMES ON AGAIN WITH THE SAME CODE. SOMEONE TOLD ME I NEED TO ADJUST THE TPS BUT I DONT SEE ANYWAY TO DO THAT.
I NEED ADVICE............. ANYSUGGESTIONS
THANX DENNIS
Old Oct 20, 2005 | 09:07 PM
Default RE: THROTTLE POSITION SENSOR (TPS)
Assuming you have an 850 there is no adjustment on the switch.Check all the wiring in the plug and make sure one of the connetors aren't backing out.
Old Oct 22, 2005 | 12:18 PM
TECH
THANX FOR YOUR REPLY...................... I M STILL CHALLANGED AND YOU ARE RIGHT ABOUT BEING AN 850, 1996, I FEEL DUMB POSTING THIS PROBLEM WITHOUT SAYING THE YEAR AND MODEL. HOW DID YOU KNOW?
DENNIS
Old Oct 22, 2005 | 02:49 PM
The way I figured it out was I checked your Profile and you pretty much only posted about 850's.
So I just assummed from there.
mdavies013
Apr 30, 2009 07:09 PM
wvuboy0207
Feb 28, 2009 08:18 PM
tityos
Feb 18, 2009 12:41 PM
Rockytop
Feb 12, 2009 08:33 AM
NSF Ed
Mar 13, 2006 09:29 PM
